When you push the 4 high or 4 low button on dash the lights on the button keep flashing and the front differential does not engage into four wheel drive. What should I check to find the problem?
I just fixed a friend of mines 96 yukon...shift to neutral press 4H and u can hear the actuator make noise (we even replaced it with a new one his idea and the same thing happen as old one), so as he hit the switch for 4H i layed under it (on 4 jack stands) and I could hear the motor on the transfer case make a loud noise (well thats working) and before all this I asked him did u check all your fuses (he said guarnteed to be all good) one night it was bothering me so i looked through the owner manual for the yukon and in the fuse box on driver side by the door there are (2) fuse for the 4wheel drive unit,pull one of the fuses good...pulled the other one and it was blown put in a new fuse and it works like brand new..pull fuse for anything that has to do with 4 wheel drive componants,
Check 4x4 actuator on front diff
On
these issue, there are few solved help links for troubleshooting the
issue easily.-------
Click
the link below: ---
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction
control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light
flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These
details will help.
Thanks.
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
4X4
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
4X4
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
4X4
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
On
these issue,there are few solved help links for troubleshooting the
Click
the link below:---
No 4x4 light on dash?
4X4 Truck makes roaring
noise in the front end?
Car will not go into 4WD
high or 4WD low?
4 wheel drive system will not disengage?
4WD light is flashing and
beeping? NO 4WD high?
2002 Jeep Wrangler: 4WD Idiot Light is ON?
Traction
4WD light
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
4x4 front differential will not engage the
axle on ford?
4x4 will not engage on Ford F150?
http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4
light keeps flashing
4X4 LOW LIGHT
IS FLASHING ON DASH
Ford 4x4 front wheels will not engage?
These
details will help.
Thanks.
On
Click
the link below:---
high or 4WD low?
Traction
4WD light
axle on ford?
Dodge Ram 4x4
4X4 LOW LIGHT
IS FLASHING ON DASH
These
details will help.
Thanks.
light flashes in 4x4 hi and low will not engage 4x4
Same deal for me.
When I push the 4x4 button the lights flash, I hear the clank when it shifts into gear but yet the front axles do not lock and only one tire spins in the rear. What could be the problem???
i have a 1992 jimmy that is doing the same thing and i was woundering if it had anything to do with the vacum accuator indicator switch that is connected to the lagest vacum line that t's off to the accuator. this switch is located on the wheel well on the passenger side by the battery.
I have the same problem...When you first start the vehicle if you put it in neutral it will allow you to put it in 4x4 but for only 10 seconds and when you shut it off it goes out. I know that it is not the actuator switch have had it tested any ideas?
