Question about Frigidaire Affinity ATF7000E Front Load Washer
E20 code on washer : will not empty water on spin cycle?
My washer goes through all the steps in washing and then at the end it beeps with and E20 error code and the clothes are still sopping wet help
  • Anonymous Mar 17, 2009
    I keep getting a E20 code and my clothes come out dripping wet, how do we fix this I have already had it in the shop 3 times.
  • Anonymous Mar 29, 2014
    Washer won't empty water at end of wash
  • 640 Answers
Something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Posted on Jan 31, 2009
What is units sump
Posted on Aug 23, 2012
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Says E20 quits washing or spinning,end of cycle beeper goes off and says E20?
This error is caused by a clogged drain filter located under the drum assembly.
Jul 30, 2011 | Frigidaire ATF6000ES Front Load Washer
Will not drain and spin keep beeping with error E20
  1. Remove the 2 screws on the bottom and the front access panel comes off.
  2. Pump is on the right, remove hoses from it, remove pump from machine and remove whatever is in the pump.
Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin LEDs should light. Any error codes should be displayed when holding those keys.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Frigidaire ATF6000ES Front Load Washer
E20 fault display
E20 is a fault either in the filter/pump or drain.
The water must be drained thru. the little hose by filter or get machine to back door and undo filter plug and drain onto back step its quicker.With filter out see if any blockages,shine torch up in filter hole turn to spin/drain and see if pump blade spins if not then get long screwdriver and turn blade to free if no joy pump has to come out to free,hopefully this will work and refit plug and check for leaks.Then try again.
Good luck.
Apr 19, 2010 | Zanussi ZWF1420W Front Load Washer
My kenmore he washer will not drain all the water also have code E20 flashing
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
I have Kenmore front load washer(don't have the model # yet)...during the normal wash cycle..at the end of it it does not spin, the diplay show E20. What seems like the problem??
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
My washing machine use to wash our clothes so well that they would come out of the washing machine practically dry... now i have to run extra spin cycles just to get some of the water out. My display often...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Jun 14, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
I am having problems with an electrolux 12680 W. PNC 914522501 2007 production yr. It was making a strange sound and not pumping out water. No problem, I removed the front plug and cleaned out around the...
the hose coming from tub to the pump has a filter in it.you need to pull filter out and empty it.E20 means that you have a slow drain,or clog.If the pump is noisier than ussual then you may need to replace pump.but check filter first.
Apr 20, 2009 | Electrolux EW1000i Front Load Washer
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Feb 17, 2009 | Washing Machines
I can't change the default wash cycle without it switching
Jan 28, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
836 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
