My FEDDERS air conditioning/ heating through the wall unit won't respond to my remote - the batteries are new and the screen on the unit won't change from " E2 ". Perhaps it is related with the snow? Anyway -- I'm cold!
  • 236 Answers
First you have to confirm if the remote control is defective. Use your cell phone camera to check the remote control transmitter. Using your camera as your eyes point your remote control to camera and "on" your remote control, light should emit in the remote control if it is good. Try to reset the error in the unit by disconnecting the power supply for 10sec. and operate the unit.If it the error code still present after the reset then you need a qualified technician for this problem.
Posted on Jan 08, 2009
I have a Mitsubishi air conditioner model SRK50ZDA-S. The remote display seems to be working fine as I can change all of the settings as normal, but the wall unit doesn't respond to it. I can turn the wall...
The remote batteries could be defective or installed incorrectly. Try removing the batteries, pressing all buttons to eliminate the possibility of a stuck one, reinstalling batteries and testing operation. If no operation, the remote may have failed or there could be failure at the wall unit.
Jan 07, 2015 | Mitsubishi Heating & Cooling
Fedders frustration
Sorry we can be of no assistance on this problem.
Mar 13, 2017 | Fedders Heating & Cooling
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
Can't find where to recharge a Fedders wall heating/airconditioner model cme015d3b
Hello, in order to rechrage the unit you must add a piercing valve to the low side of the system, most window units do not come with acess fittings. You can also add one to the high side while you are at it. Here is a link
http://www.hvacr-tools.com/mm5/merchant.mvc?Screen=PROD
May 13, 2011 | Fedders A6X05F2D Air Conditioner
Have an LE room air conditioner, the remote control won't work - new batteries and the manual control on the front panel won't go below 85 for the temperature setting
electronic module of ur ac is not working,try to remoove it carefully (only if u can) and heat all the soldered jointes with a 25 watt soldering iron,by doing so it should work if not then replace the module
Jan 08, 2010 | Fedders Appliance Air Conditioner Wall
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
I have a thru the wall fedders ac unit. The heat stopped working when you turn it on it just hums.
no blower !!! or heating element is bad or switch try putting the fan on only if it works than it is probaly the switch not letting the blower on only heat
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
New electrical wiring for split ac
Connect the two wire from the t-stat to the coil on condenser and take the 240 volt and connect it to the contactor.
Feb 23, 2009 | Fedders AED24E7F Wall/Window Air...
Heating & Cooling Logo
273 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
