Question about Frigidaire FGB24S5A Gas Single Oven
Oven will not lite
Fridgidaire FGF326ASA
When turning on the oven the ignitor lites up bright orange but the oven will not lite. doesn't seem like it is getting gas. Top burners work just fine.
  • mnarge Mar 02, 2009
    Oven has been working fine for the last year. Then all of a sudden it doesnt light. I think its more the gas than the lighter. No smell of gas is detectable after turning the knob on. Stove top works fine. Any ideas?
    Scholar:
  • 93 Answers
Unplug the unit, change the igniter maybe it does not draw enough ampage.
or check the gas control knob if somebody mistakenly turned it to off position. the ON position should be inline with the gas pipe.
Posted on Feb 16, 2009
Oven igniter works but oven doesnt lite. Strong smell of gas also. Stovetop works fine. Whats wrong!!!?
replace the ignitor,even though trhe ignitor glows orange its getting weak and cant pas enough current to open the gas valve to supply enough gas to fire the venturi tube,so it supplies gas but wont ignite this is where your odor is coming from
Jan 06, 2013 | Ovens
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
Broiler won`t lite.i replaced the ignitor but it doesn`t glow at all.sounds like an electrical problem
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
May 11, 2011 | Ovens
When I tun on the oven I smell gas, so I will turn it off and turn it back on and smell less gas and then the oven will light later.
sounds like you have a lazy ignitor and it needs to be changed out.next time send the model number and brand name so i can help you better,but it sounds like the ignitor isn't liting when it should.the flame should lite in around 40 seconds
Mar 21, 2011 | Ovens
Have xl44 gas range. oven does not work, will not lite. Has electrical power, display works just does not lite. top units are fit has gas
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Jan 04, 2011 | GE Ovens
Magic chef gas oven will not lite when turned on
heatman101
Dec 28, 2010 | Ovens
I have a frigidaire gas oven Model Number FGF366ECC. The oven does not get hot.
9 times out of 10 the oven ignitor is the problem see if the ignitor glows when you turn the oven on it should be a bright yellow glow and not a dingy orange glow if it does not glow at all the ignitor could be burned out
Nov 18, 2010 | Frigidaire Ovens
Older Maytag built in oven. starts and reaches desired temp, sometimes. Other times it never lites. electric igniter always reaches a glow
Even if the igniter glows... that doesn"t mean the ignitor is good. The igniter is wired in series with the oven bi-metal valve. Many times the ignitor will not allow the correct current to the oven valve for it to open... even though it is glowing. I would recommend replacing the ignitor first, you should be able to find one for under 40 dollars.
Aug 10, 2010 | Maytag Ovens
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 14, 2010 | Ovens
I have a gas stove - Frigidaire model FGF326ASA. The burners work fine, the ignitor in the oven glows hot and has continuity. The oven and broiler will not light. If they do, it is for a brief period.
You probably have a weak ignitor. To operate properly it should draw 3.5 amps or better. The ignitor must be bright. If it is dim it is weak.
Some repair pix
Aug 29, 2009 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
259 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
