Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
What causes ice build up on the bottom of a freezer?
This is an Admiral side by side
Check your Defrost heaters in your Freezer. I just replaced mine for that same reason.
Posted on Jan 23, 2009
    Problem Solver:
  • 3 Answers
Your drain is probably plugged so when the fridge goes on defrost the water has nowhere to go.After the defrost cycle when the frige starts to freeze again the water freezes up causing ice build up
Posted on Dec 19, 2008
5 Suggested Answers
SOURCE: I have a side by
Check to see if the doors are aligned correctlly and closing properly .
Posted on Aug 08, 2008
  • 29 Answers
SOURCE: Frigidaire side by side freezer-
this should not be happening as a heater in the freezer should eliminate this problem.first check the hose is completely clear,if it is when your fridge goes into defrost mode you should be able to feel warmth near this drain or hear the ice crackling and defrosting thence draining via the rear tube also try removing the offending ice in the drain with hot water
Posted on Aug 13, 2008
  • 111 Answers
SOURCE: ice building up in bottom of freezer of side by side MSD27 Maytag
Your defrost drain tube is clogged up. Remove the ice and look for the top of a drain tube about 3/8-1/2" in diameter. Once the ice is gone, use a meat baster (turkey baster) full off hot water stuck in the top of the drain tube and blast hot water through to clean it out. Do this several times with about 4 cups of hot water so you don't over flow the drain pan and flood the floor
Posted on Dec 20, 2008
  • 28 Answers
SOURCE: maytag side by side fridge drain blocked causing
The hose going from the drain to the condensate pan may be deteriorating or full of mold. Try running some "CLR" or Limeaway through it. Simply blowing it out with compressed air might help. If it's blocked with corrosion (metal drain) you may have to cut it free and replace it with a rubber hose.
Other causes could be that the drain is "trapping" itself or, if it came equipped with a trap, the trap could be clogged.
Posted on Jul 08, 2009
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
How to remove back panel of GS2326CEDW/11 Admiral fridge freezer
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 29, 2012 | Refrigerators
I have an admiral fridge freezer model number GS2126CEDW.water keeps leaking from the front of the freezer and a build up of frozen water has accumalated at the bottom of the freezer.A person has advised...
hello again,
Sorry to hear that the drain is clear and not the problem, some of the other things that cause that water are;
Freezer door gasket...is it curled up in the corners espicially on the hinged side so air is leaking in and condensating resulting in water
The tube that send water into the icemaker is partially frozen so when water enters the icemaker it's being sprayed and dripping to the bottom(if thats the case ice would probably be built up all over the freezer)
The door for the ice dispenser isn't fully closing and will cause condesation just like the door gasket would
Good luck,
GENE
Oct 12, 2011 | Admiral 26 cu. ft. Side-By-Side...
Hi our fridge is building up ice in freezer section & water is leaking out bottom of fridge. I cleaned ice out once but came back nxt day Cheers Wayne
The problem is caused by the failure of either the defrost thermostat or defrost heater. In any case, replacing both the defrost heater and the defrost thermostat is recommended, and that would solve your "ice in freezer" problem.
Jan 16, 2011 | Admiral Refrigerators
I have an admiral sal2027gbb and the alarm keeps sounding. there is ice building up on the back of the freezer. we have dad the sensor replaced and heating element but has not solved the problem. can you...
Could be the temp is set too low that would cause the ice build-up, thus causing the alarm to set off. Try defrosting the freezer, and run the fridge again.
Feb 03, 2010 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side, the ice maker does not seem to making ice
Pull down slightly on the bottom bin lip , and pull the bin foreward . The bin has to lock in place , or it would slide foreward , each time the ice dispensor is used , causing the freezer door to be pushed open from the force .
Jul 11, 2009 | Maytag Admiral Top-Freezer Refrigerator
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
207 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
