Question about Plantronics FRS300FR Consumer Headset
Plantronics Headset not working
My phone has a dial tone but when I switch to headset, I hear nothing...it does not seems to be working. BUt the Plantonics "box" is as when I use the handheld recevier connected to the box, i hear the dial tone. Please help!
  • 5 Answers
SOURCE: Plantronics Voyager 510 & Blackberry Curve
 Plantronics Support Phone Number: 1-800-544-4660
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE.  Device ID should appear on your screen.
Posted on Mar 12, 2008
  • 32 Answers
SOURCE: Headset has static
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
Posted on Apr 28, 2009
keekus
  • 83 Answers
SOURCE: I am getting feedback with Plantronics CS70 Wireless Headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Posted on Jul 18, 2009
keekus
  • 83 Answers
SOURCE: Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Posted on Jul 20, 2009
SOURCE: My headset has a constant buzzing in earpiece.
On left hand side of base unit dial has to be set with the number 1 in the 3'oclock position. On the right hand side of base unit there is a switch set it to the 1 position. On the headset press and hold the vol - and vol + and pick up call buttons at the same time until an orange light on headset blinks a few times.
Problem solved
Posted on Jan 06, 2010
Headset troubleshooting
I can hear the caller but they can not hear me...what is the solution?
Jul 15, 2014 | Plantronics Cs540 Wireless Headset
Binatone Acura 3000 Corded Phone with Answer Machine
Sadly you are trying to do something that the phone is not capable of doing .
Sep 12, 2017 | Plantronics Audio Players & Recorders
Bluetube is connected to my cell phone but I can't hear anything
There may be linking issues between the headset and the phone. Page 11 of the user guide offers these suggestions. Also, here is a link for re-pairing your headset to the phone:
Plantronics Explorer 230 Pairing Instructions
Remember that you want to purge any possible bluetooth interference from your phone.
"Callers cannot hear me or I cannot hear caller/dialing tone:
The headset is not turned on or the headset is not connected to mobile phone. Press the call control button for 2 seconds until you hear a beep or see the indicator light glow blue to turn headset on.
Your headset is out of range. Move the headset closer to the phone or Bluetooth device.
Your headset battery is drained. Charge your battery using the AC power adapter supplied.
The listening volume is too low. Press the volume key up (toward the earloop) to increase the sound heard in the headset."
Good luck from Headsets Direct!
Jan 10, 2012 | Plantronics Explorer 232 Bluetooth Headset
On my new Plantronics S12 Headset System, I hear a dial-tone (through the headset) when I press the headset button, but when I remove the phone and begin dialing nothing happens. I also tried a test call...
Unfortunately, the phone does matter. The S12 is designed to work with office style phones where the handset is just the mouthpiece, all other features located on the base. My suggestion is to get a phone of that style (you can find inexpensive ones at Wally world) and connect the headset following the instructions on this link for the Plantronics S12.
Jun 10, 2011 | Plantronics S12 Headset
I connected my S11 plantronics headset to my Cisco 7900 at work and can hear, but callers can't hear me
Most Cisco phones have a headset port where you can connect a headset using a special direct connect cable. This allows you to use your headset without touching the handset (receiver). However, when using an amplifier and headset combination, like the S11, you will need to connect through the HANDSET port. You disconnect the handset cable from the phone, connect the S11 cable into that port and connect the handset cable into the back of the S11 amplifier. Be sure to follow the illustrations on the back of the amplifier when connecting the cables. Also, adjust the configuration slide on the left of the amplifier for the best possible dial tone. Remember that in order to access a call or make a call, you will have to lift the handset off the phone and set it aside (switch hook needs to be activated).
Good Luck from Headsets Direct!
Jun 03, 2011 | Plantronics S11 Headset
I am trying to use a plantronics headset system and cannot get a dial tone. Is this Norstar phone compatible?
You don't say what headset it is, but I will to help you.
If this is a Plantronics corded "H" series headset you will need to use an A10 adapter cord, which plugs into the headset jack on the phone.
If this is what you are using and you don't hear anything then you need to probably need to switch to an M22 amplifier box, which is then plugged into the jack where the telephone handset was plugged in.
If you are using a wireless headset it plugs into the handset jack where the handset cord was plugged into.
Mar 03, 2011 | NorStar M7324 Telephone
Everytime i hit the blue button on the desk set i don't hear a dial tone in my head piece
Two things to remember. If you're connected through the handset jack, the handset (receiver) needs to be lifted off the phone to get a dial tone. Secondly, if you're connected through the headset jack, you may need to adjust the configuration dial (round dial on left-hand side of base) to make it work when the headset button on phone is pushed.
Aug 24, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Plantronics S11 head set does not work: hooked up properly, but non of the configuration setting yield tone. At one setting, only after the line goes into fast bipping mode (off hook for a long time) I can...
The Plantronics S11 headset system is meant to plug into the handset jack on your phone not the headset jack. Check the connection on the S11 to make sure the handset jack is where it is plugged into at.
Here are a few suggestions from Plantronics if you are not getting a dial tone:
Make sure all cable connections are correct and firmly in place.
Pay special attention that handset cord is properly connected.
Ensure AC power adapter is connected and power is on.
Make sure you have pressed the headset button and the headset indicator is on.
Make sure the telephone handset is off-hook.
Adjust listen volume control.
Adjust the compatibility slide switch.
Ensure that the headset is centered on your ear.
Aug 06, 2010 | Plantronics S11 Headset
Headset has static
Oct 24, 2008 | Plantronics CS70 Wireless Headset
Plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
Aug 04, 2008 | Plantronics PL-CS55 Wireless Headset
Plantronics FRS300FR Consumer Headset Logo
897 people viewed this question
Top Plantronics Radio Communications Experts
edward80
gggg
Jose Ma DM.
Jose Ma DM.
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
