Question about GE JGRP17 Gas Single Oven
Broiler works ovens doens't
I have a ge wall oven jgrp17wew2ww I changed the oven ingitor part eap243425 still the broiler works and the oven doesn't
can you help?
4 Suggested Answers
  • 25 Answers
SOURCE: electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Posted on Feb 23, 2008
  • 89 Answers
SOURCE: broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
Posted on May 29, 2009
SOURCE: GE True Temp Oven not heating. Broiler works
we bought a new oven
Posted on Dec 15, 2009
I have a GE 24 inch wall oven model number JRS04B0W5BB that when bake is selected the broiler element comes on and then after awhile it looses temp and does not cook anything.
Ovens often use broiler element to preheat, then shut off when set temp is reached. Check fuses for and bake element itself.
Dec 01, 2014 | Ovens
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
F7 error built-in oven
F7 is a stuck keypad error. Sometimes you can push every pad at random several times each to unstick the keypad.
If that fails the ERC(clock) will have to be replaced.
Dec 04, 2009 | GE 30" Built-In Single Electric Wall Oven...
GE JGBP90MEB oven not lighting. Broiler working
Igniter needed to be replaced. GE fixed it the same day.
Sep 18, 2009 | GE Ovens
Broiler element comes on when "bake" is pressed
May 28, 2009 | GE JTP15 Electric Single Oven
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
F3 code
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Feb 23, 2007 | GE Profile JK915 Electric Single Oven
GE JGRP17 Gas Single Oven Logo
54 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Steve Allison
Steve Allison
Are you a GE Oven Expert? Answer questions, earn points and help others
