Technics SA-GX350 keeps turning off and on - Audio Players & Recorders
  • greg_nutkins Jan 11, 2009
    I've had a technics set for some years, which has been relegated to the attic as the amp, SA GX350, cuts out when it is turned up load. It will be OK for a few minutes, and then the sound dissappears. I then switch it off and on and it does the same. I was originally informed that this is normal and you have to increase the volume slowly, but this doesn't have any effect. I have cleaned it and ensured it is in top of the stack so the cooling works better but none of this works?
    technics sa-gx350 turning the sound off - Continuing on the same problem, from the web it appears there may be two areas to look at, the fan and the cabling. I have removed the cover, and the problem occurs within 15 secs of turning up the volume, so the fan never gets a chance to switch on, so it can't be that - any other ideas?
I was given a free 350 which had this problem. Simple, cheap fix. There is a small transformer on the AC input board. That is the problem. I replaced it with a standard 9 vold AC power supply (a "wall-wart") and it has worked fine since. Fan comes on as it should and the receiver never shuts down like it did.You could get fancy with an exact replacement, but what the heck, it's a $2 transformer out of the junk box.
Posted on Jun 17, 2010
Yo compre uno en reventa y despues de un tiempo se iba el sonido del canal derecho y despues el izquierdo, lo lleve con un amigo y lo que hizo, (segun el) resoldar los integrados de las salidas y colocarles un cable adecuado a las bocinas, es aconsajable que lo haga una persona calificada, ya que es hay integrados muy pequeños o delicados.
Rene Hernandez de Xela, Guatemala
Posted on Apr 14, 2009
I have just had the same problem, if this is the same as yours.
In my case, it turned out to be the type of speaker cable I was using. This coud have been the wrong impedance or something but as soon as I changed it, it stopped cuuting out as I increased the volume.
Hope this helps.
Best regards.
Posted on Jan 01, 2009
3 Suggested Answers
SOURCE: My Technics sa GX350 tuner
Hi mate, had the same problem with my amp.. Take the top off and there is a fan at the back, there are 2 piece's of copper flat wire that touch together and these do not touch anymore so when its turned up or the bass gets stronger it cuts off as the fan should kick in at this point. If you can get these to touch again (bend them) then the problem will be gone!! I have had to do this a few times now though so this is not a long term fix.. I may try soldering!
Posted on Jan 10, 2011
  • 1527 Answers
SOURCE: Bought a Technics SA-GX350 plugged it in and it
hello check the glass fuses in side the unit
regards
shaun
Posted on May 08, 2010
How do i hook up my lg smart tv to my technics SA-GX350 stereo reciever
Connect audio outputs of TV to corresponding audio inputs on rear of receiver
Oct 22, 2016 | Technics Audio Players & Recorders
Safe to use 4 speaker with Technics Receiver?
The best thing to do is place a VOM meter to confirm that there are 6 ohm speakers
Nov 21, 2014 | Technics Audio Players & Recorders
Compatibilty
If what you say is true, you should be fine.
Where you get into trouble is having an amp of higher power than your speakers. That means you will likely blow your speakers.
Nov 12, 2014 | Audio Players & Recorders
Technics receiver SA-GX350 Receiver Manual states to be only used with 8 ohms speakers. I've used 6ohm speakers with this receiver for over 20 years. Please explain is it safe to do so?
its not safe but manageable.if the speaker impedance is too low, the amplifier will tend to overheat and more power is used up in the amplifier than is delivered to the speaker. Too many speakers on a solid state amp can burn up the power output section.
Oct 26, 2014 | Audio Players & Recorders
My Technics sa GX350 tuner keeps going into overload. It's the only thing plugged in.
Jan 01, 2011 | Technics SA-AX910 Receiver
Technics SA-GX350 Nonfunctional - Click, then nothing.
Please update the initial posting and continue the diagnosis there. The initial response is repeated below.
Thanks,
Dan
Initial response:
There could be a number of reasons for this. It woyld help if you could indicate what resistors you changed. The circuit designation should be marked on the PC board. Please post those here and I'll look further and provide some possible solutions.
Thanks,
Dan
Jul 20, 2009 | Technics Audio Players & Recorders
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
1,309 people viewed this question
 Grubhead
Grubhead
