i was trying to plug the power pack into my laptop last night but because it was dark i missed the power hole and it knocked the usb port and it switched itself off and started smoking, i left it over night and now it turns on but when it gets to the windows log in screen it stays black and a blue screen appears with white writing but i dont have chance to read it because it only appears for a second. it works fine in safe mode.
-   i turn on my computer and then a black screen comes i click start windows normally then a blue screen comes up
-   Guest
Aug 21, 2008
-   when i turn on my laptop the windows xp screen comes on then the screen goes to white. it was given to me by a friend and im trying to fix it so that i can use it.-   mamacas4
Apr 26, 2008
-   D 420 laptop, switching on power, burning smell with smoke-   Guest
Nov 06, 2007
-   I was attempting to plug in the power pack with the plug in the wall socket and must have grounded it out against the chassis or one of the other plug outlets as it now only clicks. No power when the power button is pushed in.-   Guest
Best Solution
posted on Aug 08, 2005
Ross - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
anyone know what the problem could be? drivers are not loaded in safe mode so the problem is which driver it is. try an external monitor or do a repair option when reloading xp ontop of self
but a faulse advertising and sell it on ebay say its in a good condition and then go and buy your self a good HP cause ACER sucks
Solution #5
posted on Jun 25, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
your usb port is fried .. get it reparired immedaitely from an authorized sony dealer .. they probabaly wont cover it in warranty.. or another thing could be .. press f2 at start and go itno bios and some how try to disable that usb port or both of them .. it just might work but u wont have a usb port to play with
I have bought a new Acer Aspire 5810TZ with a DVD Super Multi double layer drive. I'm probably being...
(More)
I have bought a new Acer Aspire 5810TZ with a DVD Super Multi double layer drive. I'm probably being a bit dim but there is no manual with the computer as to how to use it and I really cannot fathom it out. I would appreciate an explanation/assistance. Thanks.
why does the netbooks allow games to be played and how can i speed it up on the wi-fi.My netbook...
(More)
why does the netbooks allow games to be played and how can i speed it up on the wi-fi.My netbook runs so slow why is it when its hooked up to the wi-fi connection?
i changed the grapics card setings to be able to play dvd but now the screen is black but the...
(More)
i changed the grapics card setings to be able to play dvd but now the screen is black but the windows xp shows up at start up then there is sound but no screen
Hi Everyone, Am facing a strange problem. I have a Dell Inspiron 1000, 2.2Ghz Celeron processor,...
(More)
Hi Everyone, Am facing a strange problem. I have a Dell Inspiron 1000, 2.2Ghz Celeron processor, 256MB RAM, 80GB HDD. In the BIOS setting there is a setting for Display, which is set to XGA 14.1". This setting automatically changes to 'Unknown' & the screen does not display anything when you 'ON' the laptop. The boot up screen too is not displayed. However the laptop boots fine into Windows XP ( this is observed when you connect an External monitor to the laptop's VGA port. I have also observed that if the value in the BIOS is 'XGA 14.1" ' then only the laptop recognises the display. I have tried changing the CMOS battery , but with no results. I also tried to set the BIOS settings to 'Factory default' settings, still of no use. If at all I managed to open the BIOS settings ( whenever the display is visible), the 'Display' setting keeps on fluctuating intermittently. Also, cannot change the values manually. Kindly help. Thanks for attention.
