Question about 2wire 2700HG-B Router (2700HGB)
2Wire 2700HG-B router: what MODE? VG or mixed? or G mode?
Before I can configure my PDA to pick up wireless info, HP tech support needs to know which mode this 2700 is. Can't find anything in the the 2Wire data.
Thanks!
  • 58 Answers
Here is a link to your user guide: http://www.2wire.com/pages/pdfs/5100-000326-000.Rev.A.pdf
See page 26 (page 31 of the pdf file) - it will help you find which mode your router is set in.
Hope that helps :)
Posted on Dec 19, 2008
I have a at&t router but changed providers, can i still use it?
YES as long as your service provider authentication with the username and password:
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
this are some articles that may help...
just message me back if you still are encountering some problem - provide some error message as well and any info that may help us configure your 2wire
Sep 01, 2011 | 2wire 2700HG-B Router (2700HGB)
I don't know how to configure my 2wire 2700HG-B wireless, I need to connect my ipod. can someone help me to set them up?
hi there, first is you need to know the wireless settings of the 2wire first, the channel, SSID and the encryption.
once wireless settings are verified then you may try to go to the IPOD, go to settings/wi-fi/ then choose the network there/ try to connect to your network/if it will ask you for a network key, input that as well/ try to connect and you should be connected now.
Jun 26, 2009 | 2wire 2700HG-B Router (2700HGB)
RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Jan 16, 2009 | 2wire 2700HG-B Router (2700HGB)
I just installed a 2700HG-B and together with ATT tech support, it's working well!!!! HOWEVER, I hope to use it also for my new HP iPAQ PDA. (tech support was NOT anywhere near at helpful!!!) HP tech...
See page 26 (page 31 of the pdf file) - it will help you find which mode your router is set in. The manual says 2701 but 2wire shows the same manual for all 2700 series.
Hope that helps :)
Dec 18, 2008 | 2wire 2700HG-B Router (2700HGB)
Mode of operation for networking
Yes you need to set the 2wire to bridge mode so it wont interfere on your PBX settings and connection,,,,
Dec 07, 2008 | 2wire 2700HG-B Router (2700HGB)
Connect wireless linksys to 2wire modem
put the modem on bridge mode and set the pppoe on the lynksis router and that should get you going
Jul 27, 2008 | 2wire 2700HG-B Router (2700HGB)
I'm trying to connect my router (2wire) to my Xbox360 but don't know my WEP code.
goto the routers web interface via a connected pc at http://192.168.0.1
and read the wep setting from the wireless configuration page
make sure you dont change the settings as everything else will fail
Jul 14, 2008 | 2wire 2700HG-B Router (2700HGB)
WUSB Linksys adapter connnection
check your dns value ,firwall,proxey server, ipaddress and router configuration also.
Jun 23, 2008 | 2wire 2700HG-B Router (2700HGB)
Wiring up 2700hg-b wireless router
Hi, you will need a ethernet card in the pc to connect up a wireless router, most dont work with usb,
otherwise you would need a wireless adapter.
once you do get it connected, go into internet explorer and type in the ip adress for the router, will then come up with a menu for you to programme in your broadband details, once you get the router up and going, go into the PS3 settings, network settings, it will pick up the router all you need to do is enter the network key and its all go from there.,
ethernet card should cost you about £10 from any shop
Happy New Year
John
Jan 01, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
101 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
