Question about FIC K7MNF-64 nVidia nForce 2 Socket A mATX MB w/Snd, VID LAN Motherboard
Fic k7mnf-64 motherboard socket 462 amd 3000+ When I plug the computer in all that happens is a red light on the board comes on and a buzzer goes off.
  • rufrydrsc2 Jan 19, 2009
    When I plug in the 4 pin connector the motherboard just emits a buzzing sound at me when I turn it on. When I don't connect the 4 pin connector it turns on but won't boot.
  • barbcheck Feb 08, 2009
    I have a K7MNF-64 motherboard, I don't know how to plug in, connect the power sw, hdd led and the power led cables.
  • 1,179 Answers
Power is not going to the board. Check the power supply cables going to the board; most use a big 20 pin connector & a 2nd 4 pin connector. Make sure both are plugged into the proper spots then retry boot. Should see a green light on motherboard if power is properly set up. Hope this helps.
Posted on Dec 21, 2008
Can MSI MS-6380E support radeon x1800?
1) Motherboard uses a Socket A processor socket. Also known as Socket 462.
When they switched from the Athlon single-core processors, to the Athlon 64-bit dual-core processors, they went to a completely different processor socket.
So using the MSI MS-6380E motherboard with a dual core AMD processor = NO.
I don't seem to find an AMD Athlon 64 X2 1.8GigaHertz processor, except for a mobile version. One used for a laptop in otherwords,
Uses a Socket S1 mobile processor socket,
List of AMD Athlon 64 microprocessors,
Pretend like I'm from Missouri, and Show Me.
Find the processor by it's AMD part number, and post the URL of the website in a Comment.
AMD Athlon 64 3000+
SINGLE-core processor, not X2.
(Socket 939 processor socket, too)
Show me the Processor, and then we can go on.
Sep 11, 2012 | MSI Computers & Internet
How many slots for dram chipsets? For AZ11/ AZ31 motherboard? Thanks!
FIC AZ11 (First International Computer {Inc}
3 Ram Memory slots.
Supports SDR Sdram at 100MegaHertz, or 133MHz. (PC100, and PC133 respectively)
Maximum Total Amount is 1.5GB
Maximum Amount for EACH ram memory slot is 512MB. (1/2GB.)
Uses the VIA KT133 motherboard chipset,
(Northbridge - VIA VT8363
Southbridge - VIA VT82C686A/B)
Socket A processor socket for AMD processors. (Also referred to as Socket 462)
3 Ram Memory slots
Same type of ram memory as above, same total amount, and amount for each ram memory slot.
Uses the VIA KT133A motherboard chipset.
(Northbridge - VT8363A
Southbridge - VT82C686B
Oct 30, 2010 | FIC AZ 11E Motherboard
What is max memory for fic k7mnf-64
Supports up to 2 GB RAM 266/333/400 (aka: PC2100/PC2700/PC3200)
Sep 11, 2009 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
Need Network adapter
Install the nForce 2 motherboard drivers. The onboard network controller drivers are part of the package.
Jan 29, 2009 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
Can u fix this?
That means that ur CPU is shot. That means ur CPU is no good.
Dec 18, 2008 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
Plz help me out...problem in assembling AMD Athlon 64 processor in KVM800M board
There is no fix for that. You need a board that is the same as the original because that is the size of the processor. If that is a socket 462 processor, it is only designed and will only run in a motherboard with socket 462 on it. You need to either replace the processor or replace the board with the correct one.
Jul 03, 2008 | Mercury KVM800M Motherboard
EMachine W3052 with FIC K7MNF-64 Mobo
I did just solve all my problems with my own FIC K7MNF-64
Stop error: 0x0000007b / may be caused by attempting to load XP HOME
I've not determined exactly why attempting to load XP Home will cause
error 0x0000007b on the FIC K7MNF-64 , but it does , and it's a situaion not covered in the microsoft artical on it.
From what I can gather XP pro was the offical operating sytem for the board which I've now loaded to mine , windows 98/ME can load to it without problem so that rules out a hardware issue on my end.
eMachine T3395 or W3050 shipped with the FIC K7MNF-64 in them.
Drivers can still be obtained from eMachine for the board as of 8-26-2008
but for XP pro only from what I can see. you may need to hunt around for
98/ME drivers , even if you manage to get 98/ME drivers you will most likely still have a PCI Universal Serial Bus issue so best to load XP pro if possible. biggrin.gif
I hope this information saves some people alot of time.
May the nForce2 be with you , always.
Dec 14, 2007 | FIC (51-81677-00) Motherboard
Cannot find optical drives
The IDE cable comes with 3 IDE plugs. The longer end goes into the motherboard. The two close together goes into the two dvd drives. If you take out the DVD drives, make sure that both are not set on master. At the rear of the drive where the power and IDE connects, there is one jumper that is in line with the letters C, S or M for Cable Select, Slave and Master, respectively. One of the drives should be set to master and the other as slave. Turn on the computer and you should be able to view both drives now. Let me know if this solves your problem. Lolita
Feb 13, 2007 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
Computers & Internet Logo
610 people viewed this question
Top FIC Computers & Internet Experts
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
