Question about Kenmore 53082 / 53084 Side by Side Refrigerator
Slow leak from the water dispenser
There is a slow leak from the water dispenser and I was wondering if this is something I could fix or if I have to call an appliance guy out. My plumber capped off the water line because even thought the leak is slow, the tray underneath doesn't seem to have a water collector.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Water or switch i beleave is the water valve
Posted on Apr 05, 2009
  • marjmichael5 Apr 05, 2009
A slow drip in water dispenser
This sounds like a sticking solenoid valve. When you depress the lever for you water dispenser it activates a valve, usually at the bottom back of the fridge. It might look something like this:
25380372-1h1xuof4er41rm4qkikzo3jl-4-0.jpg Sometimes they just burn out and stop working or the seal inside fails sometimes from particulates in the water. Some people put a pre-filter on the water hose that attaches to the fridge just in case. If you have a water filter inside your fridge this does not protect the solenoid. They are next to impossible to repair so a replacement is needed. Just go to Amazon or eReplacement parts and search for your fridge model number with the search terms "water dispenser solenoid". If you are mechanically inclined you can replace yourself or get an appliance tech to do it. It's a 15 minute job.
Jan 23, 2015 | Refrigerators
Water dispenser slow flow
Hmmm...does it have a filter? I wonder if it hasn't been changed in some time or if a piece of dirt/calcium has clogged the unit?
Nov 15, 2017 | Kitchen Appliances - Others
My whirlpool ed20db ice maker isn't making ice. Inlet tube is frozen solid
Thanks for the model number. The water control valve=> W10245167 Water Inlet Valve will need replaced when this happens. Problem allows water to leak slowly into the ice maker and fill tube can become solid very quickly, or very messy ice formations coming down from ice maker, Thanks John Tripp Appliance 911
Jan 28, 2014 | Whirlpool Refrigerators
Water leaks from dispenser
Most refrigerators that leak out of the water dispenser are caused by a faulty electronic water valve not closing all the way. This is if you have a slow drip that happens. Click Here for a link to a refrigerator post leaking from dispenser. Good Luck From David from Appliance Repair
Apr 04, 2013 | Refrigerators
Constant, slow leak from water dispenser on whirlpool refrigerator
you might need to replace the bottom section and spare parts should be available readily online. I had a slow leak on my samsung side by side and it was resolved once i bought a new part...Hope this is of some use but not an expert.....
Jan 02, 2013 | Whirlpool Refrigerators
I have an insinkerator hot water dispenser with stainless steel tank, and the tank is now leaking. I'm wondering if it can be fixed or needs to be replaced
Replace water heater if tank wall is leaking.
These things have short warranty period.
Stainless steel will theoretically last longer, but steel tank water heaters have replaceable anode rod to prevent rust-out.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Be sure to recycle the old metal.
http://waterheatertimer.org/How-to-recycle-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 29, 2012 | Emerson InSinkErator C1300 Chrome...
Whirlpool ED27DQ water dispenser leaks after getting a glass of water, how do i fix this problem
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Aug 22, 2009 | Refrigerators
Water drip at doorfront water dispenser
Hi!!! Yes you can fix it by installing an antisyphon device on your water line leading to the water dispenser..remember i've done this for many years repairing frigs and they all do this they all leak water out alittle bit..Good luck..
Jan 03, 2009 | Refrigerators
Slow draining water and leaking
It needs to be inspected by an appliance repair guy. Your water pump may have a loose coupling causing low pump pressure, or the path water takes out of the machine is blocked.
Kev
Feb 24, 2008 | Washing Machines
Kenmore 53082 / 53084 Side by Side Refrigerator Logo
373 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
