Question about Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 ltd wx classic
Hello my name is mike and was wondering if you could help me?
my radio will transmit but will not receive any ideas my mic works and antenna is installed properly.
  • Michael Hogan
    Michael Hogan Apr 21, 2017
    Thank you very much.
  • 328 Answers
The mics on these cobras have a receive wire in them so the transmit will still work even if the receive wire is broken,if this wire is broken the unit will not make any sound...........remove the plug from the radio end of the mic and check the connections on the 5 pin connector.....(could be a cold solder or broken wire) or try a new mic or one that is proven work on another radio
hope this helps.................good luck!
Posted on Dec 25, 2008
I have a cobra 25 nw st and it will not transmit
Hi, my name is John. Welcome to FixYa. Turn your MIC GAIN or DYNAMIC to MAX. Try another mic on it , if that does not do the job, let me know I will have further. Thanks for choosing FixYa. good luck John
Oct 30, 2010 | Cobra 25 WX-NW-ST 40-Channels Base CB...
Hey I have a brand new cobra 25 classic ltd with eight foot whip I am receiving well but not transmitting any sugestions
Hi,my name is John. Try turning your MIC GAIN to MAX. Let me know how it goes. Could be something internal that I might could help you with...Hope this was helpful...Rate this solution on the four thumbs-up ...Good luck.... John
Oct 10, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
I have a Cobra 18 wx st. I am not able to transmit anything on it. I have checked the antenna cables and and all external connections. I receive all the wb just fine but the CB gives me nothing. I tried a...
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike. With the WX band working, the above may not apply.
See if you have a carrier...signal going out, but no modulation. Get your Tech to check the mike wiring/circuitry inside the radio, also.
Jul 06, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 25 LTD classic no transmit or receive.I have checked the mic and finals and they check ok. I beleive it might be somewhere in the VCO.Any help
With the radio on, and the case off. Rub your finger gently across the contacts of the audio chip on the trace side of the board. If you hear noise from the speaker it is good. if you don't hear anything(make sure the speaker is hooked up) then the audio chip is bad. You need to change it.
Jan 27, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
When i click the mic i get no transmit
If the receive works ok,sounds like a mic
problem,try another mic if you can find a
buddy who has a Cobra that may let you
try it most all Cobra mic will work but not all.
Good Luck
Sep 08, 2009 | Cobra 29 LTD CB Radio
I have a cobra 29 and all it will do is light up. It will not receive nor will it transmit. What might be the problem?
the easiest thing to check first is the mic..........if the mic is broken cobras wont receive or transmit
hope this helps.......good luck!
Dec 05, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29 NW LTD CLASSIC NIGHTWATCH
Dear RobertTx,
Sounds like you may have a leaky or shorted capacitor somewhere in the power circuits, or a defective transistor in the same circuits since it affects both the transmitter and receiver.
Common problems with receive and transmit intermittance can also be the antenna or its connections. The fact that it goes away if the radio is turned off, then on again after a short time points to something common in the power supply section. Unless you have test equipment and a working knowledge of electronics it will be difficult for you to troubleshoot on your own.
Jules
Oct 21, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 25 LTD 40-Channels Base CB Radio Logo
498 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
