Question about Liebert UPStation GXT2700RT-208 (GXT2700RT-208B) UPS System
Covert 230V 50Hz to 230V 60Hz
Hi my name is John
Before I retired to Santa Cruz Bolivia, I purchased five Toshiba air conditioners that were suppose to be 230V 50Hz. When the company shipped the units to my house in Santa Cruz and we opend the boxes surprize. There all 230V 60Hz. No one at this time can tell me if the units will operate correctly or I need to now by a converter or converters, for all the units. As I say all are 230V 60Hz single phase.
Help Thanks
John
    Champion:
  • 233 Answers
I would recommend that you contact the manufacturer as many units are dual rated for 50/60hz. hope this helps
Posted on May 21, 2010
    Novelist:
  • 169 Answers
To convert to 50Hz will be expensive as the Aircon needs alot of startup power. You could ask maker if 50Hz will be ok, usually motor will run slower so unit will be less efficient, alway check with maker. Or try supplier to see if they will exchange for what you ordered first.
Posted on Sep 06, 2009
My relative send me a luxor tv its 50hrz..here in the philippines we use 60hrz.,is it possible and safe
is there no small slide switch at the back of the tv
10 volt difference
may need an converter to make up 10 volts
The more significant difference is that 60Hz systems usually use 110V (120V) or thereabouts for the domestic power supply, while 50Hz systems tend to use 220V, 230V etc
read this information on the 50 and 60 hrz
Difference between 50Hz and 60Hz frequency
Nov 02, 2016 | Luxor Televison & Video
Delonghi problems
Mains voltage in Australia is 230V 50Hz. Travellers from most nations in Asia, Africa and Europe should have appliances that work on the same mains voltage as Australia - therefore you will not need a voltage converter. Notable exceptions to this are Japan, USA and Canada which uses 100/120V 50/60Hz.
If your country does not use appliances within the 230V 50Hz mains voltage range, you will need to purchase a voltage converter. This will transform the voltage from the power outlet into one your appliance can use. You will also need a power adapter.
Dec 18, 2013 | DeLonghi Gelato GM6000 Ice Cream Maker
I have kohler 12res 60hz generator can I covert to 50hz ? If yes than how can ?
No you cannot, a 60HZ unit is designed to run (and the controller expects to see 60HZ) RPMS 1800 for a 4 pole rotor and 3600RPM for a 2 pole. Slowing engine speed down to 1500RPM the controlelr would see it as under frequency
Mar 29, 2013 | Kohler 12 kW Emergency Power System -...
I'm planning to buy and use the cozy toes heating mat on 220-240 v electricity. Would that work fine with one purchased from the USA?
you will have to check the voltage before purchase because the usa voltages are different from ours they use 110v 60hz we use 230v 50hz
you would have to by a transformer if it was 110v 60hz but some exported usa appliances are 220v and will be ok you will have to check before you buy i
Dec 01, 2011 | Comfort Products Foot Warmer Mat - Cozy...
My andis T-outliner is makeing a loud noise
The problem you describe is most likely due to the fact that the machine you bought is designed to operate on 110v/60Hz electrical supply as used in North America. In fact the T-Outliner is only designed to operate on 110v/60Hz so even if you use a transformer you will only convert the voltage from 110v to 230v. You will not convert the frequency 'Hz' from 60Hz to 50Hz which is necessary with an electrical product with many moving parts such as a clipper to operate correctly on the European electrical supply which is 230v/50Hz........Check on ebay 'Voltage and Frequency Converter' about 65 pounds. The only solution
Nov 20, 2009 | Andis T-Outliner Hair Trimmer
NO instruction manual for Evesham Nav-Cam 7700
never found manual but found a site that might be able with a little support.http://www.oostdyk.com/randy/blog/2007/05/09/evesham-nav-cam-7700-gps-from-woot/
Jan 11, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Amcor split air conditioners
This should work find both being 230volt The best is to have it on its own breaker. Thank you J
Dec 19, 2008 | AmcorAire UCHW-H12AF2 Split System Air...
US portastudio 2488: Can it play when connected with a transformer
The 2488mkII manual specifies that the unit can operate with either 120VAC, 60Hz (USA/Canada), 230VAC, 50Hz (U.K./Europe), 240VAC, 50Hz (Australia) so you should be fine with a transformer which can accomodate 230VAC, 50Hz).
I have actually conversed with people who have been using the 2488 in France without any power problems.
Cheers,
bd.
Sep 12, 2008 | Tascam 2488 Portastudio Multitrack...
Have to change power input from 120V/60Hz to 230V/50Hz
ok " check the net for plug and power converters that plug in to
Singapore receptacle
Had a set for Europe worked great
Jan 22, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Liebert UPStation GXT2700RT-208 (GXT2700RT-208B) UPS System Logo
845 people viewed this question
Top Liebert Computers & Internet Experts
Computer Links
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
