Question about New World G90m Gas Double Oven
Clock No power to clock hence oven will not work. Plug and fuse okay, new clock installed, still no power?
  • Howard Nicholls Mar 30, 2007
    I am clearly not expert in this area! However I get 12volts and 50Hz at the clock. I am beginning to think that I may have been sent the wrong timer/clock as it has a different model number from the one I ordered.
    Thanks for advice.
    President:
  • 1,462 Answers
Why did you have a new clock fitted and did you do it yourself? check at the clock to see if power present. if not, check the wiring loom to see if any breaks especially at any plugs and sockets. if you do not use the automatic function, you may want to bypass the clock
Posted on Mar 29, 2007
Bottom oven stopped working. Clock display is totally blank but we have power to the oven as grill & top fan still coming on.
No make or model all pretty much the same oven power fed from clock/control either and open fuse feeding power to clock or bad clock have seen burnt wires going to clock
Apr 03, 2015 | Ovens
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
Neither the LED clock or the oven work today.
CHECK PLUG FUSE , AND SPUR FUSE IF THESE AR OK IT MAY BE YOU NEED TO REPLACE OVEN ELEMENT.
Oct 21, 2009 | Ovens
Cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
AEG Microwave oven MC2660E - no power.
Hi , open open the microwave oven check the fuse , if open replace with the new fuse .
Feb 17, 2008 | Ovens
New World G90m Gas Double Oven Logo
439 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
