Question about Sharp AR-M237 Copier
I have a AR-M237 small copier and I need to put in some new account codes and delete some old account codes. I have a manual but it doesn't seem to tell me how to accomplish this. Please help.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
You need to have the ADMIN code to access, change, edit, delete or install new codes. Look in the Management setting under user tools. Look for user codes or key operator codes. Defualt ADMIN code is normally 000000 or 11111, that is if the ADMIN code was not changed.
Posted on Jan 05, 2009
Cover door spring replacement
It helps to have a small tool called a spring hook. Other than that it will function if you tape the cover closed.
blog.equipmybiz.com
May 10, 2013 | Sharp AR-M237 Copier
I got an error code L3-00 on my Sharp AR-M237 can help you. dalmircfranck@hotmail.com
The L3-00 means that the scanner is not in home position. You can try turning off the machine and unplug it for a minute or so and then turn it on. If that doesn't work you can take off the glass and cleaning the rails the the scanner slides on and then put a slight and I mean slight layer of lubrication on the rails like ATF.
Oct 15, 2011 | Sharp AR-M237 Copier
SHARP AR-M237 H2-00 ERROR CODE---HAVE INSTALLED NEW FUSER UNIT WITH SAME ERROR/CODE PROBLEM.
check harness and connector betwen thermistor and control PWB.
clear the error code by using SIM 14 if all didn't work you may have defective AC power supply
I hope this help
Feb 10, 2011 | Sharp AR-M237 Digital Copier
U2-40 code
CLEAR THE ERROR
Enter SIM
# - * - C - * - 16 - START
Mar 31, 2010 | Sharp AR-M237 Copier
Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Oct 08, 2009 | Sharp AR-M237 Digital Copier
I need to change the IP for my ar-m237
Try to increase the router range to include the ar-m237 or change the copier to a lower IP address within the range of the router.
Jan 03, 2009 | Sharp AR-M237 Copier
I need to put in some new account codes and delete the old ones
You need to be in the ADMIN. to change / enter codes. There is a separate code for the ADMIN. Input that code and you can change, edit, add new codes. If the ADMIN code was not ever changed then it will be the default code in the manual. Be ready because the code is not where you think in the manual. I believe it is is the setting section or check management settings. The default is usually 000000 or 111111.
Dec 18, 2008 | Sharp AR-M237 Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Changing Security Code
pleaz see the operating manual ,main code is 00000
Aug 02, 2007 | Sharp AR-M237 Copier
Sharp AR-M237 Copier Logo
209 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
