Question about Proficient S12 Subwoofer
Fuse Where is the fuse so i can replace it.
It is below the subwoofer A/C plug and you need to pull it out
Posted on Nov 22, 2009
Blown fuse on fuel pump 1996 Ford explorer Replaced fuse drove vehicle home. Now it will not start.
A blown fuse is an indication of circuit overload. Did you replace the fuse with one of the same value or higher? is this the standard current rating for that circuit (usually marked on the fuse cover.
If the engine cranks remove a spark plug tape it to the intake manifold or somewhere where there is clean bare metal (please not near the battery) check for spark if ok reinstall plug if not replace the ECM fuse and relay with alternatives in the fuse box if this gets the pump going replace the ECM fuse and or relay then check for fuel turn on the ignition you should hear the pump run and then shutoff if not replace the pump fuse and relay with alternatives in the fuse box if this gets the pump going replace the pump fuse and or relay
Feb 11, 2016 | Ford Cars & Trucks
Tip
How to replace an auto fuse
Cars and trucks use fuses for many different components. Every now and then, one of the fuses will blow. You can take your car to a mechanic if you want, but it will be much cheaper to replace the fuse yourself.
Replacing a fuse is different for every vehicle, but the same general procedure applies. The first thing you'll have to do is get a replacement fuse. Open your vehicle's fuse box (typically either underneath the steering wheel or under the hood -- your owner's manual can tell you exactly where) and locate the blown fuse. All fuse boxes should include a diagram that tells you which fuse controls which components, so you can tell where the blown fuse is. If you have a circuit tester or multimeter, you can test the fuse to verify that it has been blown.
Once you've found the bad fuse, get a replacement fuse of exactly the same size and rating. Most auto shops or hardware stores sell fuses, typically in variety packs for a couple of dollars.
When removing the old fuse, you can use your fingers or a pair of tweezers, or you can get a specially-made fuse extractor (which is just a fancy pair of tweezers). You can also use needle-nose pliers, but if you do, be careful not to squeeze too hard and crack the fuse.
Make sure the car is turned off when removing or installing a fuse. Put the new fuse in gently, facing the same direction as the old fuse. Once it has snapped into place, close the fuse box and turn the car on. Test the component that the fuse controls and verify that it works. If it doesn't, the fuse may not be pushed in all the way, or the new fuse may be bad.
on Mar 04, 2011 | Honda Accord Cars & Trucks
Replacing 140 amp fuse in lexus gx 470
Replacing 140 amp fuse in lexus gx 470 - Fixya
www.fixya.com/.../t26021201-replacing_140_amp_fuse_in_lexus_gx_4...
24 mins ago - The battery in my lexus gx 470 needed to be replaced it was hooked up wrog and the 140 amp fuse was blown how do i replace the 140 amp ...
HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS ...
www.fixya.com/cars/t24496313-replace_140amp_fuse_lexus_gx470
May 24, 2014 - HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS GX470CAN"T GET THE FUSE BOX APART TO UNBOLT THE FUSE - Dodge 1997 ..
Dec 25, 2015 | Lexus GX 470 Cars & Trucks
Black decker bna17 mini fridge
I am having the same problem. Replaced the fuse with fuse holder and 3A fuse but the new fuse blows immediately. What do the diodes look like? and how do you replace them?
Sep 19, 2013 | Refrigerators
Need to replace the fuse in space 19 in the under the hood fuse box of my 1999 Chevrolet Tracker>
Take off the negative battery terminal first. Use pliers to pull the fuse remnants out. If not enough room, try removing surrounding fuses. The fuse only has two spade terminals into the fuse block. Pull on them back and forth until loose.
Feb 19, 2013 | Chevrolet Tracker Cars & Trucks
Fuse panel diagram
Fuses
Print
REPLACEMENT
See Figures 1, 2, 3, 4, 5, 6 and 7
Fig. Fig. 1: The power distribution box in the engine compartment contains fuses and relays
Fig. Fig. 2: Remove the cover for the interior fuse panel
Fig. Fig. 3: A fuse puller tool is located inside the fuse panel to aid in the removal of the fuses
Fig. Fig. 4: Grasp the fuses with the puller and pull straight out to remove the fuses
Fig. Fig. 5: There are generally four types of fuses used in these vehicles
Fig. Fig. 6: Fuse current rating and color code chart
Fig. Fig. 7: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made
Fuses protect all the major electrical systems in the car. In case of an electrical overload, the fuse melts, breaking the circuit and stopping the flow of electricity.
If a fuse blows, the cause should be investigated and corrected before the installation of a new fuse. This, however, is easier to say than to do. Because each fuse protects a limited number of components, your job is narrowed down somewhat. Begin your investigation by looking for obvious fraying, loose connections, breaks in insulation, etc. Use the techniques outlined at the beginning of this section. Electrical problems are almost always a real headache to solve, but if you are patient and persistent, and approach the problem logically (that is, don't start replacing electrical components randomly), you will eventually find the solution.
Each fuse block uses miniature fuses (normally plug-in blade terminal-type for these vehicles) which are designed for increased circuit protection and greater reliability. The compact plug-in or blade terminal design allows for fingertip removal and replacement.
Although most fuses are interchangeable in size, the amperage values are not. Should you install a fuse with too high a value, damaging current could be allowed to destroy the component you were attempting to protect by using a fuse in the first place. The plug-in type fuses have a volt number molded on them and are color coded for easy identification. Be sure to only replace a fuse with the proper amperage rated substitute.
A blown fuse can easily be checked by visual inspection or by continuity checking.
The fuse block is located on the lower left side of the instrument panel. To access the fuse panel, open the driver's side door. Pull off the fuse panel cover to get to the fuses. Spare fuses and a fuse puller should always be kept here. Various convenience connectors, which snap-lock into the fuse block, add to the serviceability of this unit.
REPLACEMENT
  1. Locate the fuse for the circuit in question.
When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating.
  1. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
  2. Continuity can also be checked with the fuse installed in the fuse block with the use of a test light connected across the 2 test points on the end of the fuse. If the test light lights, replace the fuse. Check the circuit for a short to ground or faulty device in the circuit protected by the fuse
Aug 10, 2012 | 2000 Pontiac Sunfire
Dashboard lights dont work
Try to adjust the dashboard dimmer switch.
or check for fuses:
CIRCUIT PROTECTION Fuses REPLACEMENT Fig. 1: The power distribution box in the engine compartment contains fuses and relays 91146p01.jpg
Fig. 2: Remove the cover from the interior fuse panel (located on the far left of the instrument panel) 91146p66.jpg
Fig. 3: A fuse puller tool is located inside the fuse panel to aid in the removal of the fuses 91146p67.jpg
Fig. 4: Grasp the fuses with the puller and pull straight out to remove the fuses 91146p68.jpg
Fig. 5: There are generally four types of fuses used in these vehicles 88256g69.gif
Fig. 6: Fuse current rating and color code chart 88256g70.gif
Fig. 7: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made 87956094.gif
Fuses protect all the major electrical systems in the car. In case of an electrical overload, the fuse melts, breaking the circuit and stopping the flow of electricity. If a fuse blows, the cause should be investigated and corrected before the installation of a new fuse. This, however, is said than done. Because each fuse protects a limited number of components, your job is narrowed down somewhat. Begin your investigation by looking for obvious fraying, loose connections, breaks in insulation, etc. Use the techniques outlined at the beginning of this section. Electrical problems are almost always a real headache to solve, but if you are patient and persistent, and approach the problem logically (that is, don't start replacing electrical components randomly), you will eventually find the solution. Each fuse block uses miniature fuses (normally plug-in blade terminal-type for these vehicles) which are designed for increased circuit protection and greater reliability. The compact plug-in or blade terminal design allows for fingertip removal and replacement. Although most fuses are interchangeable in size, the amperage values are not. Should you install a fuse with too high a value, damaging current could be allowed to destroy the component you were attempting to protect by using a fuse in the first place. The plug-in type fuses have a volt number molded on them and are color coded for easy identification. Be sure to only replace a fuse with the proper amperage rated substitute. A blown fuse can easily be checked by visual inspection or by continuity checking. The fuse block is located on the lower left side of the instrument panel. To access the fuse panel, open the driver's side door. Pull off the fuse panel cover to get to the fuses. Spare fuses and a fuse puller should always be kept here. Various convenience connectors, which snap-lock into the fuse block, add to the serviceability of this unit.
  1. Locate the fuse for the circuit in question. NOTE: When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating.
  2. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
  3. Continuity can also be checked with the fuse installed in the fuse block with the use of a test light connected across the 2 test points on the end of the fuse. If the test light lights, replace the fuse. Check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
prev.gif next.gif--- Or, try to look for burnt out bulbs in instrument panel.
Sep 18, 2010 | 1999 Chevrolet Malibu
I bought my car used from someone and it didnt come with the owners manuel and the cover of the fuese box is missing so i need to know which fuses r wich!! plz help
REPLACEMENT
  1. Locate the fuse for the circuit in question. NOTE: When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating. On some vehicles, you may have to remove a cover for access to the main fuse block 88256p51.jpg
    The fuse panel cover has a label with the fuse designations on it 88256p52.jpg
  2. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse. Locate the fuse which needs to be checked . . . 88256p53.jpg
    Fig. 1: Fuse locations and component identification 88256g71.gif
    Fig. 2: After you pull the fuse from the block, check the element 88006p42.jpg
    Fig. 3: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made 88006g76.gif
Jul 14, 2010 | 1996 Chevrolet Corsica
2002 Mercedes C320 wagon / fuse for cigarette lighter
Just did this on my 2002 C320. The blue 15 amp fuse is located in the front fuse box under the hood. It is either #47 or 48. If you already opened the driver-side fuse box, see if the paper fuse map is still there. If it is, find the fuse to be sure. Replacement is very easy, but there is a fuse puller tool in the spare tire well where your kit of replacement fuses should be. if you are in luck and you have a replacement, use the puller tool and replace the fuse.
Mar 02, 2009 | NAD C320 2-Channel Amplifier
I have a 2005 Nissan Xterra SE. 95,000 miles. I have hazards but my directionals have stopped working. I believe its a fuse but I cant locate which fuse to check?
if your fuse box doesn't tell you which fuse is which, just pull them one at a time and replace any that are blown. if not a fuse, replace bulbs
Nov 30, 2008 | 2005 Nissan Xterra
Proficient S12 Subwoofer Logo
234 people viewed this question
Top Proficient Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Proficient Audio Player and Recorder Expert? Answer questions, earn points and help others
