If the radio on your 2001-2005 Honda Civic (as well as some other Honda products) has lost power for any reason (i.e. dead battery, blown fuse, etc), you will need to enter the reset code.
The reset code for the factory installed radio is located in the glove box. Open the compartment; On the back of the door, usually near the left side, there should be a small white sticker. The sticker has one alph-numeric set and one set containing five numeric digits. The number set with five digits is the reset code for your factory installed radio.
Turn on the radio. When you see "CODE", use the corresponding station pre-set buttons to enter the code. If entered correctly, the radio should active immediately.
You need to input the radio code to get it to play. Take it to the dealership parts counter and they can get it for free. It has a theft lock so if the battery is disconnected you need to input the code.
These are known as theft deterrent codes, so that said they would not publish them on the internet. To get the code you need the radio chassis serial number and the cars VIN number and either see the dealer or go here: www.radiocodes.com
The reset code for the factory installed radio is on a sticker in the glove box. The sticker has 2 set of numbers. The number set with 5 digits is the reset code for your factory installed radio.
the dealer is the only one that can unlock a locked radio, they will need to remove the radio, get a "code" off of the sticker on the back of it, and then call the dealers unlock assistance number to get an unlock code. it cant be done with out the dealer. im sorry :(
If the original factory code doesn't work, you need to pull out the radio and get the serial number on the side of it. Then contact the car dealer or the manufacturer and they would give you the code.
The code that you are referring to is also called the anti-theft code. This code is unique for each radio. No body could provide you the exact code except for the dealer or manufacturer.
