Question about JC Whitney - Audiosonic 3-way Custom-fit Overhead Sound Bar Car Speaker
I have a audio sonic in car power supply n348 and i have plugged it into my lighter in the car and cant find the chanel or frequency?is there a frequency that is best suited. I have plugged it into my mp3 player and need to listen to musioc????
The battery is dead and i i cant get in the bonnet
Get a 12v power supply. Put a car cigarette lighter attachment on it. Plug it into one if your cig lighter accessory outlets and that my give enough power to your battery to open the hood
Feb 26, 2014 | Vehicle Parts & Accessories
When i search radio chanel with SCAN UP of DRA-275rd radio, he stop on a near frequency but not exact frequency, so i cant to tune in a station. could you help me please?
Check on the back of the unit for a switch marked "channel step" or something similar.Usually close to the anntena socket or connection.When you find it switch it to the alternative position.This should solve your problem.
Jun 18, 2011 | Denon DRA-275R
Cigarette lighter fuse blows out too often, which one is it I changed all the 20A fuses, but cannot figure out which one it is beyond this I use the lighter to power my satelite radio
its not a 20 amp fuse,its a 5amp fuse, I had an XM Roady and its the plug they use on the radios power supply plug,they are cheap, buy a new cig lighter plug and wire it to the XM Radio power supply plug, and it will cure your problem
Feb 23, 2010 | 2000 Chrysler Concorde
The radio won't keep the memory settings of the chanels.. How do I get it to keep them ?
Most radios have a yellow memory wire,(sometimes it is red) This wire needs to be connected to a constant power source, i.e. battery, cigarette lighter. It needs to be connected to something that when the vehicle is turned off, it still has power.
Nov 22, 2009 | Pioneer DEH-2100 CD Player
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Whister 1200 Inverter
if the inverter is wired to a lighter socket then you do not have enough power as lighter sockets are generally limited to 100-150 watts. If you are using the supplied battery clamps, then is the vehicle running to supply enough power to run your TV?
Sep 25, 2009 | Whistler PI-1200W 1200-Watt Power Inverter...
My TV only has sound on a few chanels. The picture is on all chanels.
Check your settings. If you have "high end audio" settings set or it's set to deliver on a specific frequency, the other stations may not be able to deliver.
Jul 03, 2009 | GE Televison & Video
Cant get all of my channels
I LOST MY BOOK HOW DO I PROGRAM MY RECEIVER
Feb 18, 2009 | Motorola DCP-501 Receiver
Screen wont turn on after 3-4days
when starting the vehicle, the unit gets a surge. disconnect before starting the car. If it has a cig lighter power adapter, it was not meant to stay plugged in 24-7
Dec 18, 2008 | Car Audio & Video
Car Audio & Video Logo
Top JC Whitney Car Audio & Video Experts
Jaime Hernandez
xxxxxx xxx
Are you a JC Whitney Car Audio and Video Expert? Answer questions, earn points and help others
