Question about Pioneer DEH-P3700MP CD Player
Accidently removed the tiny screws behind faceplate
Did I just ruin this stereo? I removed the 4 tiny phillips head screws on the front of the stereo (behind the detachable faceplate).
I can tell that something came loose behind the front plate. Any way to fix?
Thanks.
  • jeffgrum Dec 20, 2008
    Thanks for posting your feedback scrapin_96. I was able to fix the problem myself shortly after posting my question. What I had done with removing the screws was releasing the 4 black clips that stick out of the faceplate that hold on the face of the stereo. I fixed it by working on it upside down so that gravity was on my side. I think that there are some magnets that help put the clips back in place. When the clips were back in position I was able to put the screws back in and they luckily grabbed the clips back into place. All of this was done upside down with only one person. It would have been easier with a second pair of hands, but got it fixed! Thanks.
    Problem Solver:
  • 4 Answers
It could just be a plastic clip that broke.Most of the car stereo's ive taken apart only have a thin ribbon of wires that run into the contacts that your face plate connects to.If you actually took screws out of the faceplate then id put them back in and put it back into your stereo and see if it illuminates properly,if it does not then id search on E-BAY or contact pioneer and buy a replacement but most the time it would be cheaper to just buy new stereo.You might want to be more specific with the area you took screws out of,the way im reading it sounds like you unscrewed the screws in the face dock, not the faceplate.Hope this helps.
Posted on Dec 20, 2008
How to remove the drivers door panel on a 1991 honda accord lx
Instructions
    • Insert the narrow edge of the flat head screwdriver behind the edge of the plastic screw covers located on the door pull as well as the rear of the door panel. Remove the Phillips screws located behind the covers with the Phillips screwdriver.
    • 2Insert your flat head screwdriver behind the plastic screw cover located behind the door release. Remove the Phillips screw from behind the cover with the Phillips screwdriver, then slide the door release handle forward and remove it.
    • 3Insert the panel tool behind the front of the door's upper edge to pry out the triangular piece of plastic located there.
    • 4Pry around the edges of the door panel with the panel tool until the panel is loose.
    • 5Lift upwards on the door panel to slide it off the door. Unplug any electrical connectors that are plugged into the back.
Oct 01, 2012 | Cars & Trucks
Onkyo DX-C100 Service Manual
Here is repair manual http://www.givemefile.net/smanuals/cd_dvd_blue-ray_audio_players/onkyo/file/5743.html
Apr 01, 2012 | Audio Players & Recorders
I have a cd stuck and can not eject it . Dealership is telling me $1000.00 and I want to get the stereo out of the dash and see what the problem is myself first
To remove the radio, start with removing the faceplate for the stereo by removing the two phillips screws on the bottom of the faceplate, then there are two tabs on the top that will come loose once you swing the bottom of the radio faceplate out. Then there are 4 phillips screws holding the radio in place, two on the sides and two on the bottom.
Jun 03, 2011 | 1997 Toyota RAV4
How do you take of the dash paneling to install a new aftermarket cd player?
  • Disconnect the negative battery cable from the Jeep Cherokee battery with the 10 mm wrench.
  • 2 Remove the five screws on the top edge of the dash panel with a Phillips-head screwdriver.
  • 3 Pry the trim panels surrounding the climate control knobs away from the dashboard with the trim panel removal tool.
  • 4 Remove the trim panel that surrounds the headlamp switches (located to the left of the steering column) with a trim panel removal tool.
  • 5 Remove the two screws behind the trim panel that surrounds the headlamp controls with a Phillips-head screwdriver.
  • 6 Pull the dash panel that surrounds the stereo and covers the instrument panel of the Cherokee, away from the dashboard by hand.
  • 7 Remove the two screws from the stereo mounting bracket. One screw is on the bottom left corner, the other screw is on the top right corner. Each screw can be removed with the 10 mm socket and drive.
  • 8 Pull the factory stereo from the stereo mounting dock.
  • 9 Disconnect the stereo wiring from the back of the factory unit.
  • 10 Connect the Jeep Cherokee factory stereo wiring to a wiring harness adapter. Connect the wiring harness adapter leads to an aftermarket stereo. Slide the aftermarket stereo into the stereo mounting bracket and replaced two screws at the opposite corners with the 10 mm socket and drive.
  • 11 Replace dash panel that stretches across the top of the steering column.
  • 12 Replace the two screws at the top of the headlamp control switch. Replace the trim panel around the headlamp switch.
  • 13 Replace the trim panel that surrounds the climate control knobs.
  • 14 Replace the five screws on the top edge of the dashboard with a Phillips-head screwdriver.
  • 15 Replace the negative battery cable over the negative battery terminal and tighten the cable to the negative lead post with the 10 mm wrench
  • Dec 24, 2010 | 2006 Jeep Grand Cherokee
    Dash removal on 1006 mercury grand marquis
    Hello, to remove the dash follow this steps:
    1. Pry all the woods pieces off of by pulling them away from the dash.
    2. Use two ford radio removal tools to remove the radio in the marquis. Place one tools inside two of the four holes in the front of the radio, and the other tools in the other two holes,Pull them away from each other and out of the dash board. Disconnect the wiring harness from the back of the stereo.
    3. Remove the screw surrounding the radio using a Phillip head screwdriver. Do not forget to remove the two on the other side of the radio.
    4. Remove all the screw around the instrument cluster using a Phillip head screwdriver.
    5. Use the steering wheel tilt level to tilt the steering wheel all the way down .
    6. Gently pry out the dash , making sure to disconnect the two wiring harness behind the dash board panel before pulling it out completely.
    Thanks
    Aug 24, 2010 | 2003 Mercury Grand Marquis
    Replace broked water actuator
    You will need the new actuator, regular Phillips head screwdriver, putty knife, and jeweler's screwdrivers.
    1. Go to this link to view the parts diagram.
    2. Carefully peel part #14 using putty knife.
    3. Remove 3 screws part #43
    4. Carefully remove part # 4. Note, there are fragile plastic arms that snap into place to hold the top of part #4 in place. I used a flat jeweler's screwdriver to apply pressure to the arms so they did not snap off.
    5. Once you have removed #4, you will be able to see the top side of the actuator. There are three Phillips head screws which hold it in place. Just remove those screws, install the new actuator, and replace the screws. Note you may need to remove three Phillips head screws holding #8 in place to get to the screws holding top of actuator. Do this carefully or the wiring harness which attached #8 to #38c will pull out which adds extra steps (If this happens, see below).
    6. Replace all parts following the above steps in reverse.
    7. I used a small amount of contact cement to restick #14 but it was probably not necessary.
    If you accidentally pull the wiring harness from step #5 above out, you will need to remove the circuit board cover to replug it. There are 4 tiny Phillips head screws which hold the cover in place. Remove them using a jeweler's screwdriver, replug the harness, and carefully replace the cover.
    Apr 30, 2010 | Frigidaire Refrigerators
    2 discs stuck in console
    WOW!!! I am so sorry that this happened. Nintendo products are really hard to open. If you cant wedge the game out with a small screwdriver, dont worry about the game, here are the directions on opening it. Just copy and paste to word so you can see the whole thing easily.
    How to open your Wii Console Step by Step Instructions
    To disassemble:
    1. Flip the device upside down and remove the small silver Phillips screw. Once out, remove the battery tray from the console.
    2. Next remove the rubber foot directly above this battery tray. Also remove the three square white stickers from the bottom of the Wii. The rubber foot and the sticker are covering hidden screws. Figure 3 provides a shot of where these screws are located. NOTE
      Hiding screws under stickers and rubber pads is a common method used by electronics manufactures to help increase the aesthetics of their devices, as well as prevent people from easily locating screws and taking apart their products.
    3. Unscrew the two Triwing screws and three Phillips screws from the bottom of the Wii.
    Figure 3 - Bottom Screws
    1. Flip the Wii over onto its right side. Locate and remove the two rear rubber feet and the two rectangle stickers near the faceplate.
    2. Remove the two silver Triwing screws in the holes and remove the two black Triwing screws on the faceplate (Figure 4).
    Figure 4 - Left side screw locations
    1. Flip the Wii upright and carefully remove the two socket covers. They come right out with a little wiggling.
    2. Remove the three black Phillips screws from the black plate (Figure 5). Note the one closest to the faceplate is the longest and will need to go back into that hole when putting the Wii back together.
    Figure 5 - Top black plate screw locations
    1. With the screws removed, carefully pull off the faceplate of the front of the Wii. You will need to disconnect the red/black wire plug from the Wii to remove the faceplate completely. Figure 6 shows what is hiding under the faceplate.
    wiifig06.jpg Figure 6 - Under the Wii faceplate
    1. Remove black plate from memory/controller socket area.
    Remove two silver Phillips and two silver Triwing screws from memory/controller socket area (Figure 7). wiifig07.jpg Figure 7 - Topside screw locations
    Lay the Wii on left side (with the ATI and Nintendo logo facing you) and slowly work the right side cover of the console off the device.
    This will take a little bit of force. If something appears to be stuck, double check to ensure you removed all the screws.
    Locate and remove four screws holding DVD reader in place. Two are located in plain site in the middle of the unit. Two are located near the front of the Wii inside the DVD unit (Figure 8). wiifig08.jpg Figure 8 - The insides of the Wii
    Slowly tilt the DVD player upward toward top of Wii. There are two wires that need to be disconnected before you can safely remove the DVD unit. One is a plug type of connector that only requires a little tug. The other is a circuit strip connector that requires you to lift the brown catch, which will release the pressure holding the strip in place (Figure 9). Do not break this!
    May 11, 2009 | Nintendo Wii Console
    Display issues with Aiwa CDC X207
    I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
    You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
    I purchased them from Union Electronic Distributors:
    https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
    Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
    Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
    1) Remove the faceplate from the radio and bring it to a well-lit work table.
    2) Remove the four Phillips screws on the back on the faceplate.
    3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
    4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
    5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
    6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
    7) Solder the new bulbs in place. They are not polarity sensitive.
    8) Trim off the excess wires.
    9) If you installed the two screws in Step 4, remove them.
    10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
    11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
    That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
    Hope this helps.
    Ron
    Dec 13, 2008 | Aiwa CDC-X204 CD Player
    Took the lint screen out and forgot to put it back in and a kneehigh went in the vent and made a noise. Is there any way to get it out without repairman. I cannot see the nylon and the machine is stacked...
    This being stacked makes things a lot more of a pain. Disconnect power.
    • Remove three phillips head screw at the back side of the dryer top
    • Slide top back about an inch or so and lift off
    • Remove two phillips head screws at 5 and 7 O'clock position on dryer bulkhead just behind dryer door.
    • Remove two phillips head screws on top front edge of dryer
    • Tilt dryer front forward at top and unplug door switch at top of door and light socket at top left.
    • Lift off dryer front, holding until you can unplug the moisture sensor wire at the bottom, then set aside.
    • Remove the four phillips head screws at the sides of the dryer holding the front drum support assembly.
    • Lift up assembly and pull toward you to remove.
    • You now have access to the blower.
    • Front of blower can be removed. (1/4 hex screws)
    Oct 03, 2008 | LG Dryers
    How to change my faceplate
    The face plate snaps on, unless your talking about changing the front LCD cover. Then I would take it to my local service provider store and let them do it. It's there job.
    Jul 02, 2007 | LG C1500 Cellular Phone
    Pioneer DEH-P3700MP CD Player Logo
    232 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Marvin
    Marvin
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
