Question about Plumbing
Slow running tap
We have a Danze NSF 61/9 faucet the problem is the water is running out very slowly - both hot and cold - any suggestions??? thx
  • grarosso Mar 26, 2009
    hi, i have the same problem, i cleaned the screen but this made no difference. any other suggestions?
  • Anonymous Mar 26, 2014
    Cold water does not run after hot water
  • 35 Answers
If you have recently turned off your water supply you may have disturbed some sediment in the water lines causing this problem.....Unscrew the airator at the end of the faucet and there is a screen inside( take note how this screen is in place). This should give you water pressure back!
Posted on Dec 19, 2008
  • 491 Answers
Posted on Oct 11, 2009
Danze upc NSF 61/9 single lever faucet w/spray in head
I am in England and cannot buy a replacement nut. We lost the original one.where can I buy one? They don't do the right size in England!
Jan 23, 2012 | Danze Plumbing
After installing the thermo bypass valve on the furthest sink faucet from the water heater, the sink faucet has no pressure, and there is hot water slowly comling out of the cold water valve.
It sounds like the installation loosened sediment inside pipe.
Remove sink aerator and see if you can flush open the faucet.
Also check if other faucets are receiving hot water from hot-and-cold taps that says if grundfos is pumping hot water from the water heater correctly.
When recirculation pump is running, both hot and cold water lines have hot water.
If other faucets have hot water in both lines, then that tells you the blockage is localized in furthest faucet supply lines.
You may have to dissemble those supply lines and flush the sediment out.
Dec 30, 2010 | Grundfos Comfort System Recirculator ...
Bought a home, main kitchen faucet is a Danze NSF
I'm not familiar with a NSF 61/9, but I've used several other models. I believe these are all ceramic disc valve. They almost never wear out. If you remove the handle and the trim cap or bonnet, there should be a nut or adjusting ring you can tighten. Don't over do it. The handle give you quite a bit more leverage than the small tap when it is removed. Here is Danze web site and you can look up your exact model number and see a exploded parts list:
Jul 12, 2010 | Danze Plumbing
Lack of Hot water pressure
If its a tap refurde to, remove the head at the front of the tap and clean out the filter in front, if the houses warm water has low presure u must find ur presure redusing velve located on main cold feed to geyser and clean the cartrage out revit and ur presure must then be vine , let me know if that dosent help
May 28, 2010 | Danze & Single Handle Tub And Shower...
My Danze NSF 61 9 makes a loud howling noise ant almost any level of water flow. I have tried to adjust the water preasure but it does not help. Any ideas?
Brand new ours did not have this problem. It does now and I think the reason is the seam in the chrome over the handle is cracked and pressure leaks out causing the noise. It's now bad enough that it leaks also. Glue fixed both problems temporarly but its doing it again so I'm looking for a replacement. That's how I came across this post.
Jan 02, 2010 | Plumbing
Looking for parts breakdown picture for DANZE NSF 61 Kitchen Faucet Any Links?
NSF 61(-9) is a standard rather than the model number (it's often very difficult to identify the model number. If you are able to find the model number, the link attached has all the technical specs for Danze products (even discontinued ones).
Otherwise, I suggest browsing their faucet section until you find yours.
Good luck.
Sep 13, 2009 | Plumbing
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Danz cartridge removal
Loosening the set screw behind the small plastic hot/cold plug will allow you to lift the handle straight up. You may need to jiggle it a little bit or twist it, just pull straight up with the faucet handle down and centered. Once the handle comes off, Then the collar should thread off exposing the inner workings of the faucet. You should then be able to unthread a bunch more components and washers until the cartridge top is exposed (depends somewhat on whether it is a pullout hose or seperate sprayer...not sure exactly what model you have but this is the standard for a single handle kitchen faucet...)
Here is a link to a page that shows how your (hopefully your) faucet goes together... also includes the re-order info for cartridge (#8)...[1].pdf
I would also check the supply stops to make sure they are not clogged, because it is definetly a sediment problem.
Jan 23, 2009 | Danze Fairmont Double Handle Roman Tub...
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to and order them there.
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Plumbing Logo
2,458 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
