Question about Kenmore 41389 Electric Double Oven
Fault code F7....
Keeps coming on after getting a message that says "Push Start for lower oven" with constant beeping. I bought this used and did not get a manual. Could you please help?
  • josh613 Jul 21, 2008
    When attempting to self clean after 1 minute the self clean comes up end and an error code F7 flashes and beeps. This is on the Fischer Paykel single oven. What can I do?
    Sniper:
  • 68 Answers
The root cause of most F7 problems is a short circuit in between the two segments of the ribbon cable. In cases with a metal touch panel, there could also be a short circuit between the ribbon cable and the edge of the slot in the touch panel. __The solution is the same for both problems. Add insulation. My fix which has worked for hundreds of cases is to simply place a slip of paper in between the two sections of ribbon cable and for metal touch panels, also between the ribbon cable and the edges of the slot. Try to work the insulation down into the slot at least 1/8". See the attached photo which shows my solution. The short circuit is caused by what is known as a dendrite. This is a form of corrosion that is quite common to printed circuits. Moisture is the primary culprit.____Cleaning the contacts is often suggested. This only works for a short length of time. The movement of the cable temporarily interrupts the short circuit, but with time it grows back again.____Using the self cleaning feature seems to accelerate the deterioration of the cable.____Don't worry about putting paper in the top of oven. It will not get hot enough to burn. GE places service instructions in the top of the oven.____Be certain to turn off the power to the oven before opening the touch panel.____This problem is the result of a design defect in GE ovens that is common to ovens produced since 1998.
Posted on Apr 14, 2007
  • Charlie  Popeck
    Charlie Popeck Jun 07, 2007
    Hi. Cleaning the connection is a short term solution. Here is what is happening. You remove the ribbon connector and in the process you are moving the cable all the way back to the slot in the touchpanel. The F7 problem comes from a short circuit between the two sections of ribbon cable. The movement temporarily disrupts the short circuit, but it will grow back again. My fix prevents the short circuit from returning.
A sheet of paper trimmed to fit between the ribbons; a small piece of electrical tape on the metal edge; problem solved! You are a genius. Possible savings of 200-500 dollars. Dennis C.
Posted on Dec 08, 2007
Simple solution that saved me time and money. I cut the power to the oven, removed the three panel screws, opened the panel, inserted the paper, secured with electrical tap, put it all back together and the problem was solved.
Thanks,
Raz, Phoenix, AZ
Posted on Dec 16, 2007
"Powerman", Solution #6 is spot on. Worked like a champ for me.
Posted on Apr 18, 2010
I woke up this morning at 4:30 a.m. to what I thought was my fire alarm, it turned out to be my 7 year old Kenore Elite double oven, that had gone crazy. I ended up flipping the breaker a couple of times and then just shut it off till I could figure out what to do. I got online looking for a solution and thanks to powerman found a solution that was great. The instructions were clearly written and so easy to follow. I am a 53 year old woman with no mechanical skills, but with this solution a screwdriver and an index card I fixed my F7 problem in less than 10 minutes. Thank you again.
Posted on Oct 07, 2008
This solution worked for me, too! Thanks for the advice!!
Posted on Mar 01, 2008
So far so good.that explains why the first time i moved the ribbon cable the f7 stop for about a yr then it came back.this is a good tip thanks
Posted on Aug 31, 2007
I got the "F7" on my GE oven. Tried your "piece of paper" solution and IT WORKS! Thanks very much. Al, Austin Tx
Posted on Jun 09, 2007
I CLEANED THE CONNECTION ON THE RIBBON AND THAT SOLVED MY PROBLEM ON CODE 7
Posted on May 08, 2007
4 Suggested Answers
SOURCE:
Powerman
  • 68 Answers
SOURCE: Oven error code
See my solution to OVENMAN/April 12, 2007. I have supplied my fix to over 650 individuals and have had a high reported success rate.
Powerman
  • 68 Answers
SOURCE: Kenmore Gas wall oven flashes F7 Code
Hi Indy2008,
You can find my solution to the most common cause of the F7 problem at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have helped over 1600 folks solve the F7 problem. The problem is usually with the touchpanel and not the ERC. My fix tells how to determine which part is faulty. Hopefully you will not need to purchase a new touchpanel, however, if you do, an internet search will lead you to lower cost sources.
Please let me know if my fix works for you. You can email me at:
hutchipop@yahoo.com
Regards,
Powerman
Posted on Mar 22, 2008
  • 30 Answers
SOURCE: kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Posted on Nov 08, 2009
JKP15 Electric Single Oven: Oven keeps beeping with F7 error...
F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
May 07, 2010 | GE JKP15 Electric Single Oven
Our Maytag Oven keeps flashing F7 and beeping we tried to push cancel and nothing happened so we have turned the power to the oven off. What do we need to do to fix it?
Contained within the oven, usually behind the backgurad, there is a tech sheet. DISCONNECT POWER and pull off back panel behind backguard to locate sheet. Within this sheet there are a list of fault codes and the corrective procedure.
Aug 24, 2009 | Ovens
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Mar 04, 2009 | GE Profile JT910SASS Electric Single Oven
F7 code keeps flashing, nothing on keypad works. I can use second oven with the dial and also my counter range top but the F7 won't go away, nor the beeping. I can push the start button or stop and F7 will...
After much searching, I have found that you have a faulty keypad.
The recommended solution is to unplug the oven, or shut it down at the fuse box, and then remove the faceplate where you can then remove the keypad, and clean the connectors with an eraser, as well as the ribbon that connectes the keypad with the oven.
I hope this helps out.
GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Aug 19, 2008 | GE JKP15 Electric Single Oven
Hi Indy2008,
hutchipop@yahoo.com
Regards,
Powerman
Mar 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Double oven
ovenman, there's not a complete model number here but in the Kenmore line F7 is the code for a stuck function switch or bad keypad. Makes sense that it's telling you to start the lower oven. Try removing the ribbon cable from the board and cleaning the ends with an eraser. Reseat it and see if the code comes back. Make sure to kill the power before doing this. Catriver..post back.
Mar 28, 2007 | Kenmore 47732 / 47734 / 47739 Electric...
F7 message with beeping
The F7 represents a shorted matrix or start key. To determine whether it's the key panel or control itself, disconnect the ribbon cable of the key panel that goes to the control and power the oven up. If the F7 does not come back, it's the key panel, if it comes back, it's the control..
Jun 09, 2006 | GE JKP15 Electric Single Oven
Kenmore 41389 Electric Double Oven Logo
2,524 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
