Question about Dell Inspiron 6400 Notebook
Dell 6400 battery blinking
Can you help me with this.
this morning the red light blinking, for low battery.
it was fine until today.
  • 3 Answers
The blinking is a warning that the battery is dying (like all batteries eventually do). Save the life of your next one by unplugging the battery when its plugged into the wall for long periods of time.
Posted on Dec 18, 2008
  • Dell Master
  • 5,568 Answers
I assume you've had this on charge?
The charge monitoring hardware is capable of measuring not only the state of charge to prevent cooking batteries but also how long they have been on charge.
Your battery pack has multiple cells in it and when one of those cells shorts (turns into a piece of wire), the circuit watching over things compares the time charged and the current state of charge and concludes that it ain't never gonna get there because of that one bad cell. The voltage simply won't rise far enough to make the monitor happy.
I suggest to everyone that they have a cheap Chinese digital multimeter at home to check things like that. You don't need a diploma from Stanford to use one and even at Radio Shack they are well under $20 US and include a sometimes intelligible Chinglish instruction sheet. With one of these, you can remove the battery pack, read the specs from the label and then start randomly measuring between any two contacts. You will eventually find two that give you a reading on the 20 VDC range. Nimh cells (the most common) have a characteristic voltage of ~1.5 volts each and if the pack (for example) says it should be 12 volts, it then needs 8 cells to deliver that.
If you are measuring ~10.5 volts or thereabouts after it should be charged, one cell is dead; this = new battery pack.
  • Steve Allison
    Steve Allison Dec 19, 2008
    A correction to my earlier post; NiMh cell voltage is ~1.2 volts, not 1.5.
    So a pack specfied at 12 VDC would need 10 cells and the loss of one cell would result in a maximum terminal voltage of ~10.8 volts.
    Alkalines, carbon-zinc (older type 'flashlight' battery) supply ~1.5 V and the previous 'king' of rechargeables, NiCad cells are also 1.2 V.
    Just another step in senile dementia -
I own a Lenovo Mini Wireless Mouse (Model number N30). It has been working fine since the last 4 months I have owned it. However, I noticed today that the small light on the top of the mouse is blinking...
It's indeed the low batteries indicator. I have a Lenovo N30 myself.
I suggest you use a good pair of rechargeable AAA batteries.
They last longer than regular alkaline.
Best regards.
Source: Lenovo N30 User's Manual. Own experience.
Feb 17, 2011 | Lenovo Mini Wireless Laser N10 Mouse
Dell inspiron 6400 touchpad and keyboard work intermittently. battery light was flashing red this morning. i have to hit the keys several times before they work. laptop is plugged in.
sounds like your main battery needs replacing,move your mouse over the battery icon in the system tray(by the clock),to see if the battery is charging. If it is battery needs replacing. This can cause all kinds of strange issues .
Oct 12, 2009 | Dell Inspiron 6400 Notebook
Wont turn on
Well to be3 a 100% about the battery I would replace it with one that you know or is guaranteed to work. Camera batteries can look OK from outside and be completely collapsed inside.
No Charge lights can indicate NO battery and if there is one inside then it is dead and registers as a no battery ( no charge light)
The red light blinks in very low state, but totally discharged it will not blink and wont blink again until loeft on chareger for about 3-4 hrs to overcome the low state.
Jul 25, 2009 | Kodak Easyshare M753 Slim Digital Camera
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
i cant figure out how to turn on the croll for my inspiron 6400 touch pad
Mar 05, 2009 | Dell Inspiron 6400 Notebook
Flashing red and green battery light dell 6400
Ok, probably not the battery. With Dell machines, once they overheat to a significant level, it locks an overheating code into the bios, so you will have the light codes at start up. I've had three C840 machines with an overheating issue come through my shop. In order to get the machine working again, you will have to fix the problem that caused the overheating, then there is a download at Dell's site to clear the code. If the initial problem isn't fixed the code won't clear. On the machines that I worked on, 1- had a hair wound in the fan and the other 2 had bad fans one burned up the processor. I believe the 6400 and the C840 is basically the same machine. It's been a while since I worked on those machines so I can't remember exactly where the clearing download is at Dell's site, I do remember reading several forums at Dell on the subject. I hope this approach helps a little more than my last. If you have any more questions please ask.
Jul 09, 2008 | Dell Inspiron 6400 Notebook
Blinking red light
blinking red light with battery icon means that you are running out of battery power. if the computer is plugged in to the wall and it still does the same thing you may have to replace the ac adapter or charger. the charger should have a green light on it to indicate it is getting power.
hope this helps. thanks.
Nov 13, 2007 | Dell Inspiron 6400 Notebook
Flashing icon at the top right of my Dell Inspiron 6400
seems your battery cell is the one having that issue. try replacing the battery or plug the laptop and let it recharge the battery to full.,
Oct 28, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
195 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
