Want to register my router - Computers & Internet
Go to the router manufacturers website and I'm sure there is a link you can click on the register it.
Posted on Dec 18, 2008
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
Changed ISP provider and is not able to connect to internet through linksys wireless router, model # wrt160n
Have you gone to your new ISP providers website, and surfed the internet?
I know, most routers have to be registered to gain access to the internet.
You might have to manually input the MAC address (found on the bottom of the router) to your ISP, then sometimes it takes anywhere from 5 minutes to 1 hour for the router to register, depending on your ISP.
After the router is registered, you can plug or wireless connect to the internet.
Sep 09, 2010 | Linksys Wireless-G WRT54G Router
Register
you can register through linksys website.
Apr 03, 2010 | Linksys WRT160N Wireless Router
What link do I use to register my router and PCI Adapter card?
Just go to www.linksys.com.
In the upper right corner, you will see Register Products. Or simply click this link.
If you already have an account, just sign in with your email address/username then password.
If you are not yet registered, then just click on the Register button and fill out the form.
After registering, you may register your products.
Hope this helps!
Jan 07, 2010 | Linksys Wireless-G WRT54GS Router...
Router Won't connect to internet
The cable modem sometimes register the hardware MAC address of the connected device. So your PC may be registered and it won't accept the router now. Connect the WAN port of the router to your cable modem and power the modem off and on again. It should re-register the connected device and now your router should work.
Jul 30, 2009 | Dell TrueMobile 2300 Router (000001)
Remote manage a DSL 504T router
If you have a dynamic IP on your wan port you shall register a domain name and register it with dynamic DNS, provide your dynamic dns name in your DSL router so that you shall connect to your DSL router by calling the registered dynamic dns name from any where (you should have internet connection).
1. Register a name in dyndns.com
2. update this on your dsl router
Wait for some time,
3. access the registered name from anywhere using a browser
Jun 09, 2009 | D-Link DSL-504T/EU Router
Registering
what are you trying to register? I've never registered my router? Do you mean you just bought it and you want to register it with the company? try their website or see if you got a registeration form in your documents that came with it.
Mar 17, 2009 | Linksys WRT54GL Wireless-G 54Mbps...
BUT IT IS NOY COMING THE PREVILAGE MODE(ROUER>)
normally if you forget the password with cisco, boot the router in rommon mode and change the registry to 0x2142 and reboot the router and change the password and change back the registry to 0x2102.
did you tried this all ...can u explain more about the same
Feb 09, 2009 | Cisco 2610XM Router
Computers & Internet Logo
20 people viewed this question
Alun Cox
David Payne
David Payne
