Cats Logo
Anonymous Posted on Aug 15, 2012
How can I avoid the smell coming from the litter box?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Aug 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
19
Questions
7
Helped
6987
Points
57
I'll require some consistency on your behalf; you should clear out the waste frequently, a couple of times a day, and keep the box itself as clean as possible.
1 Related Answer
Anonymous
  • 15 Answers
  • Posted on Aug 14, 2012
SOURCE: How can I avoid and prevent a smelly litter box?
You should get into the habit of scooping the waste at least twice a day. You should completely empty and clean the litter box once a week. Scrub the pan and scoop with detergent and a small amount of bleach to disinfect and then rinse thoroughly.
tip
Keeping your cats litter box smelling fresh
If your cats litter box is not cleaned every day, or the litter is not changed frequently, the odor will build up. Here are some tips that will help you keep litter box odor at a minimum:
ā€¢ Never put your cats litter box in your own bathroom. The best location for a litter box is in a small closet; preferably somewhere you keep your cleaning supplies.
ā€¢ Avoid using hooded litter boxes. No matter how clean you keep it, the hood will trap odors.
ā€¢ Try lining the bottom of the litter box with a thin layer of baking soda.
ā€¢ Opt for a clumping cat litter. They make it easier to remove waste.
ā€¢ Use a litter box deodorizer.
ā€¢ Be diligent about cleaning the litter box and area surrounding it
The following is a great brand of litter that neutralizes odors upon contact with moisture. I have noticed a difference since we started using it.
http://www.tidycats.com/Products/PremiumScoop/SmallSpaces.aspx
on Aug 28, 2012 • Cats
Smell and flies
Change your litter often (daily) and use Worlds Best Cat Litter.
2answers
What are the advantages of covered litter box?
Covered litter boxes prevent stains on walls from cats that usually stand up to ***** and scattering of litter by cats that scratch excessively inside the litter box.
Aug 15, 2012 • Cats
Is Silica gel litter safe for kittens?
I would avoid using Silica gel litter in a kittens litter box and wait until they are slightly older. Young kittens are prone to tasting cat litter (simply out of curiosity). Silica crystals can be harmful if ingested and for this reason alone should not be used.
Aug 14, 2012 • Cats
Is it better to get a covered or uncovered litter box for my cat?
I prefer uncovered litter boxes. Some cats may become claustrophobic in a covered litter box, giving them a sense of being trapped. Although covered litter boxes may seem like an appealing method of reducing odors throughout your home, consider how your cat will feel. A cats sense of smell is much stronger and more sensitive than ours. Lastly, covered litter boxes can trap a lot of dust. This may seem advantageous; however it is quite the opposite. The dust can be very difficult on your cats lungs and become very unhealthy.
Aug 14, 2012 • Cats
I heard from a friend that it is not safe to handle cat litter when pregnant. Is this true?
This statement is partially true. Pregnant women can safely handle unused cat litter; however used cat litter should be avoided. Cat ***** has been known to transmit a disease known as toxoplasmosis; which can seriously harm an unborn baby.
Aug 14, 2012 • Cats
How can I make my cats litter box smell better?
The most effective way to having a nice smelling litter box is to keep it clean. To achieve this you will need to scoop out ***** and stool daily and change the litter every 4-7 days.
Aug 14, 2012 • Cats
Aug 14, 2012 • Cats
2answers
My cat litter tray get very smelly and embarrassing how can I make it better?
The best way to avoid smelly litter trays is firstly keep them out of site, use your laundry room or out house. Secondly clumping litter helps to minimize kitty litter odors.
May 14, 2012 • Cats
Top Cats Experts
Don A
Don A
ADMIN Andrew
ADMIN Andrew
EPSCO LLC
EPSCO LLC
Level 1 Expert
Are you a Cat Expert? Answer questions, earn points and help others
