Question about Logitech Webcam
Quickcam E3500 when i connect hear my voice on other computer like echo
    President:
  • 8,637 Answers
That's because they are using their speakers to lesson to you. If you both use headphones then you won't get the echo. Also you can have them try to lower the volume at their end.
Hope this helps.
Posted on Jan 31, 2009
Echo occurs on voice chat
just down the mic volume and see als run the sound diagone test.
Sep 08, 2009 | Logitech QuickCam Communicate STX Personal...
My friend can't see me but she can hear me. I can see and hear he
If you have a conflict with your printer - disable the printer during cam sessions
make sure your cam is configured to Skype
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your Logitech device as the default microphone. For example, select Logitech e3500
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your Logitech device as the default Webcam. For example, select Logitech e3500
  7. Click Save.
  8. Test logitech by making a Skype test call.
Aug 24, 2009 | Logitech QuickCam Pro 5000 Webcam
Skype sound test
This means you need to tweak the volume levels a little and maybe also change the recording levels.
Echo is a common thin with VOIP communications and it may not go away fully but tweaking your levels shoul minimise it.
Also do not use VOIP type communications on low speed connections
Jul 28, 2009 | Logitech Quickcam Chat Webcam
Camera doesn't come on when I try to activate installation.
sotware for cameras dont work for apple unless in UVC mode means plug and play. here is a list of cameras compatiable to apple computers.
amera Name P/N QuickCam E3500/E3560 860-000095 QuickCam Ultra Vision SE 860-000023 QuickCam Ultra Vision 861238 QuickCam Orbit/Sphere MP 861305 QuickCam Fusion 861304 QuickCam Pro 5000 861306 QuickCam Pro 9000 861464 QuickCam Pro for Notebooks 860-000026 QuickCam for Notebooks Pro 861303 QuickCam Communicate MP (S5500) 860-000106 QuickCam Communicate Deluxe (S7500) 860-000107 QuickCam Communicate Deluxe 861235 QuickCam Deluxe for Notebooks 860-000009 QuickCam Vision Pro for Mac 860-000143
QuickCam Orbit AF 860-000063
Jul 11, 2009 | Logitech Quickcam Chat Webcam
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
Video sound problem
Durring video conferencing with MSN Messenger, I can't hear my friend and he can't hear me. Or I can hear them but they can't hear me. What's wrong? trnsp.gif Answer This article applies to the following products:
All Logitech Web Cameras with MSN Messenger Support
This article applies to the following software:
Windows XP
Test the Microphone in Sound Recorder
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
If the microphone does not work in Sound Recorder, click here for help in determining the problem with the mic.
While using MSN Messenger it is the messenger program, not the camera software, that negotiates the audio streams between two MSN Messenger Clients. Although we cannot directly support audio issues in MSN Messenger, the following steps have been known to resolve and improve audio issues in MSN Messenger. For further information, please consult the help documents associated with MSN Messenger.
Test Your Networking Router
You can also test to see if your router is causing audio issues by either physically bypassing your router and connecting directly to your cable/DSL modem or by setting up your computer as the DMZ (de-militarized zone). If you are a novice networking user, it is not recommended that you leave your computer in the DMZ state for extended period as that may leave your computer vulnerable to attack. However, you may briefly configure your computer as the DMZ to determine if your network settings are causing the audio issues. For DMZ setup instructions, please consult your router's documentation.
Enable Universal Plug and Play (UPnP) on both Windows XP and Your Router.
If either of the above steps resolves the no audio problem, try the following steps.
  1. Open Add or Remove Programs in Control Panel. To open Add or Remove Programs, click Start, point to Settings, click Control Panel, and then double-click Add or Remove Programs.
  2. Click Add/Remove Windows Components.
  3. In the Components list, select the Networking Services check box, and then click Details.
  4. Make sure the Universal Plug and Play box is checked.
Notes: If you used a CD to set up Windows, you will be prompted to insert it into your computer.
If your router does not support UPnP or you still get no audio after enabling UPnP on both Windows XP and your router, you must manually open all UDP ports between 5004 and 65535. This is because the audio streams are sent dynamically using that range of ports. Without a dynamic way to open those ports like UPnP, there is no way for MSN Messenger to successfully negotiate the audio stream. Consult your router's documentation for instructions to manually open these required ports.
If you are still experiencing audio issues within MSN Messenger, and you have verified that the microphone is working in Sound Recorder, contact MSN Messenger Support.
This article covers Accoustic Echo Canncellation (AEC) and how it works.
QuickCam 10.x and RightSound supported cameras
QuickCam 11.x and RightSound supported cameras
Call Central and RightSound support audio devices
This article applies to the following platforms:
Windows® 2000 Professional
Windows® XP Professional
Windows® XP Home
Windows® Media Center Home
Windows® Vista
Accoustic EchoCancellation (AEC)'s purpose is to prevent sounds from your computer's speakers to be picked up by your microphone. This can be a significant problem with audio or video calling applications where the voices or sounds from other parties of the call is being inadvertently picked up by the microphone and fed back into the call, creating echo and other sound distortions. Without AEC, this echo can detract from the quality of a call and in extreme situations, the echo can degrade the audio experience to the point where the audio is useless.
To prevent this from happening, the AEC component monitors sounds being played by your computer's speakers while monitoring the incoming sound picked up by your computer's microphone. The AEC module takes the outgoing and incoming sound signals and compares them to determine if echo is present. If echo is found, it is subtracted before the audio from the microphone is sent to the requesting application. This will result in the remote party only hearing you speak, without being distracted by hearing their own voice echo back to them.
When enabled, echo is eliminated for the recipient of the audio/video message. For echo free chatting, both parties need to have a RightSound technology enabled web camera that supports the AEC feature.
Apr 05, 2008 | Logitech Quickcam Chat Webcam
Hello Shemon
Well, there is 2 option here, 1) your sound speakers are not connected corretly or in the right slots on the sound card.
2) your sound card, (internal or external) you have to use the mixer on software to put the right channels for the music you heard. try configuring in control panel, in multimedia devices, the speakers. for 5.1 system, or 2 way speakers or 3
try again
Dec 25, 2007 | Bose Companion 3 Computer Speakers
Echo
Try the following: Go to the Control Panel (in classic mode). Open Sound devices. Change tab to Voice / Microphone. Press Test Software. Wait a couple of seconds. A small guide begins now. The problem is that the Microphone volume is set to high. Try to adjust these settings and see where it gets you. Usually does it for me. Also, try to not have the mic near the speakers. (I translated the steps from my swedish version of XP, look for similiarities.)
Apr 03, 2007 | Logitech QuickCam Fusion 961403-0403...
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
