Question about Sony Playstation 3 (PS3) Console
Still no sound
We have a standard TV and have used 3 pin AV cable with a Euro AV connector (SCART). The picture is fine but we have no audio....can you help. Have selected correct audio option in settings and still no sound
    Problem Solver:
  • 34 Answers
PS3 is The amazing device by sony but it has some common problems like sound but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Feb 27, 2009
What does scart mean?
images?q=tbn:and9gcsq3imtjhqb0abmt8dptscde8waay3n_hlomxu7sbdjgyrsqmaoxypwoa
A SCART connector is a physical and electrical interconnection between two pieces of audio-visual equipment, such as a television set and a video cassette recorder (VCR). Each device has a female 21-pin connector interface. A cable with a male plug at each end is used to connect the devices. (The 21st pin is actually not a pin but a ground shield contact.) Stereo audio, composite video, and control signals are provided in both directions. RGB video signals are input only. The interface is an industry standard
originated by the French company, Peritel. Today, most new television sets and VCRs in the European market and other countries that use the PAL video standard come equipped with a SCART connector. SCART stands for Syndicat francais des Constructeurs d'Appareils Radio et Television. The connector is also known as a Euro-connector.
Although it is possible to build your own connecting cable, knowledgable people recommend buying a commercial cable because of the detailed pin-crossovers and close pin connections. Differerent cables serve different purposes. A cable for connecting a VCR or a TV set to a high-fidelity audio system needs to use only three of the 21 pins.
It is more difficult to use the SCART connector to interconnect a VCR to a computer monitor because of the difficulty of synchronizing the composite video signal (which is companded into red, green, and blue) from the VCR with the RGB signals needed by the monitor.
Feb 16, 2012 | InFocus IN72 Multimedia Projector
HOW I CAN HAVE OUTPUT FRO AUDIO LINE ROM LG 55LH5000???
Hi, sorry but Most LG's no longer have audio outputs. The easiest way to get it ,You need to take the audio output from the source i.e. "cable box output"..if you have of course...
However whether your TV has this output or not we need to make some tests..5 different connections possibilities provided below.
(not by priority..you can start with any of it ).Below ,there is a sample TV back panel picture as well
Possible CONNECTIONS:
1) 2x RCA ports red / white is audio out ( L + R ) of TV to Stereo..
2) You can get also the audio digital output from the TV to a A/V receiver. the tv's optical audio out is stereo only mainly designed for freeview or tv audio to be output,
set the audio ouput on the TV menu to Dolby Digital, connect a digital optical out directly to the A/V receiver to receive audio signals.
3) since your TV has :2 x HDMI, SCART, AV, Component Video, VGA-sub, USB 2.0, connections,you may use the SCART plug to get Audio output for your TV .
TV's SCART connector which has 21 pins and "2x Audio Output " pins should be in it.
you need to buy an adapter called " RGB Scart Male to 3 RCA AV Female Adapter Converter" that can easily be found any electronic Market..one example as found eBay URL is below..
http://cgi.ebay.com/RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter-/130389078197
After you get this adapter,you need to carry the audio signal from SCART's RCA plugs to your Receiver with a 2x RCA (white/red ) cable.(if this does not work ,mfg should state somewhere in the manual..as your TV's "SCART socket IN only" ) if you properly connect IN/OUT plugs you will able to get the audio signal of the TV thru stereo..I recommend 2 $ value "RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter" with IN/OUT switch on it.
4) use HDMI connection of TV if you have HDMI input on your stereo of course...
5) if these are not an audio-out on one of these connectors , so you'll need to use the headphone socket if you want to plug it into a stereo. you need a cable 2x RCA to 3.5mm Headphone jack.
( This is the last ditch solution , since it mutes the whole sound.) ..
NOTE: if you connect this, pls be careful,your TV voice level will drive the stereo volume....
Hope this helps!..if more help requires Would you please let me know the result ?
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for us
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Sound but no picture on either SCART socket inputs
open the tv and check for dry joints on the jacks of AVS, if no dry joint is found
the ariel in put is different from AV inputs
change the AV in IC. AT THE W/SHOP
Apr 25, 2009 | Goodmans 257NS 20" TV
Have set up PS3 but we have no sound -
you must go to the audio setup menu and select what audio output cable you are using
Dec 18, 2008 | Sony Playstation 3 (PS3) Console
Panasonic TV: TX-28DTX10,VCR nv-HV60 EB, DVD:SC-HT 520
EC means euro connector, I.E. Scart socket. For some reason there is no video signal coming out of the scart cable/out of the VCR or being displayed on the TV. Try plugging the scart plug into a different scart socket and see if that helps.
Sep 14, 2008 | Panasonic TX-32PL10 32" TV
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
Sony Playstation 3 (PS3) Console Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
