Question about RCA RT2760 System
Volume increases on its own intermittently
While watching tv the other night, the receiver began increasing the volume on its own. I lowered it w/the remote. It did it again after several minutes, and this time I could not fight it with my remote. I just turned it off. Last night I tried it again. I got 30 minutes through my show before it happened again. The volume level starting increasing on its own!
  • jgmelger Dec 29, 2008
    Yes, the display changed, from TV to numbers (for volume), and I watched the numbers increase before my eyes (freaked me out too).
    I was alone. No other signal would be able to hit the receiver.
    You mentioned remote batteries....interestingly enough, the remote died soon after this occurred! I thought it was a coincidence, but maybe not?
  • chipster2 Feb 28, 2009
    My volume goes up on it's own as soon as I turn on tv. Remote no longer works either for channel or anything. Took out batteries on remote, tv still does the same thing. The volume bar on tv increases with the volume, I tried to manually turn it down but it goes right back up and I can't maually change channel when this happens either until volume has increased all the way.
When the volume increased did the display show it doing so as if someone was turning the knob?  I mean did the volume go from like level 15 to 30 or did the unit's level stay constant while the audio volume increased?
Were you alone or sharing the room with a jokester who has a universal remote?
Does this problem occur when the batteries are removed from your remote?
Are you sure the 'volume up' button on the unit itself is disengaging properly after being pressed?
Posted on Dec 29, 2008
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Porsche cdr22 volume increases and button will not dcrease
Most of these things use an IC to control things like volume etc. Chances are that will have failed.
Feb 25, 2013 | Pyramid Cdr22kit Am-fm Receiver Cd Player...
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
I have the SR6200 and I am finding I have to really crank the volume to get the same sound that I used to have on a lower volume setting----I have not changed anything---any ideas? This is occuring with...
sounds like you have an issue with the cables/leads from the receiver to the other equipment? try buying a new set of cables and/or check that the pins/plugs are in correctly, they may have been disturbed? wiggle the plugs on the leads at the back of the receiver whilst it is playing music/tv and do the same to the rear of the dvd/tv/cable unit. if you get intermittent increase in the volume it is likely that the cable has a break in one of them? good luck
Sep 12, 2009 | Marantz SR-18EX Receiver
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Sep 07, 2009 | Pioneer VSX-816-K/S Receiver
Volume increases on it's own intermittently, takes itself off of mute.
Let's eliminate ghosts and goblins.
As a test, locate the remote control window on the front of the unit, if it has one. Set it up to watch or listen to something then cover the remote window on the unit with a small piece of cardboard. If you can't locate its infrared receiver for the remote just cover the entire front of the unit with something sufficiently opaque to block your remote. Try to operate it with th remote to be sure the unit can't see it.
If the expected problem never comes back you have a stray signal from something else in the environment getting interpreted as a 'volume up' command. Then look around for other remotes being used, wireless devices, use your imagination. I used to have a remote-controlled space heater and my TV would sometimes shut off if I used the remote. Does the unit have line-of-sight to a nearby house? Maybe something next door (garage opener?) is interfering.
If it still happens and there are no other infra-red devices nearby you have a ghost.
Apr 28, 2009 | Pioneer VSX-D409
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
HAVE TO UP VOLUME ON DENON 2106 TO HEAR ALL AUDIO IN NIGHT MODE
There should be a volume adjust on the center channel. This is done by the remote exclusively. You may also wish to compress the sound using the dynamic range compression button or so labeled.
Aug 31, 2007 | Denon AVR-2106 Receiver
RCA RT2760 System Logo
489 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
