Question about Epson Expression 1680 Professional Flatbed Scanner
I get a wide vertical blue line when I scan
My scanning was normal, then suddenly a wide vertical blue line appears under the image. As well the image  gets centered on the preview, rather than being in the corner as it is on the flatbed. Don't know how to fix this. I'm sure I've done something unknowingly! It is Epson Perfection V350 Photo.
5 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: I have vertical lines in my photos when i scan them
If the lines are in the same location for all scanned outputs, it is clearly dust on the scanner glass. Clean it thoroughly.
S. Mohan, India
Posted on Jul 09, 2009
  • 63 Answers
SOURCE: EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Posted on Aug 21, 2009
SOURCE: How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Posted on Nov 17, 2009
  • 526 Answers
SOURCE: How to cleas Epson Perfection 3200?
use a lint free cloth, slight moisten the cloth and clean the glass.
do not spray anything on the glass.
Posted on Dec 02, 2009
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
Have a Phaser 6110 MFP. When I scan a page using the ADF I get 3 color lines running vertically down the image. If I don't use the ADF, the page scans without the lines. What could be causing this?
There are some small spots on the "seal" glass. It is the 3/4 inch wide strip under the scanner, not the main glass. Clean that strip well, I suggest taking some rubbing alcohol and just a regular piece of paper, crumpled up. Use that to clean that strip vigorously.
That will take care of it.
Jan 06, 2010 | Xerox Phaser 6110 Laser Printer
Vertical lines in image -- appears that belt is stuck
If the same image is scanned repeatedly, it appears like a line. Check if there is paper is moving (in high speed scanners) or the scan module is moving (in Flatbed scanners). If this is normal, all you need is to clean the glass thoroughly.
S. Mohan
Aug 08, 2009 | HP Scanjet 5400c Flatbed Scanner
Vertical line in scanned image
This is because of dust sticking to the glass. Clean with isopropyl alcohol (rubbing alcohol) and dont use solvents. For emergency you can use your after shave but take care only to clean the glass portion!
S. Mohan, Chennai, India
Jul 08, 2009 | Kodak i40 Path-Through Scanner
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp 5400c scans blue images
sounds like a faulty scanning head to me......
when images are scanned they are normally imaged in 3 colours red blue and green these are then combined to give a full colour scan. sounds like you are only getting the blue pass.
not alot that can be done here, if it is in warranty (check with manufacturer for duration of warranty as sometimes this can be more than a year) they should repair or replace this for you
Apr 23, 2009 | HP Scanjet 5400c Flatbed Scanner
Vertical lines through scanned images.
You should clean the small glass under the top lid. Chances are there is some white out or ink or mark on the glass. Look carefully because usually it is just a small dot>
Dec 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Epson Expression 1680 Professional Flatbed Scanner Logo
474 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
