Question about Proview PL926WBi 19" LCD Monitor
Monitor only stays on a few seconds
Can turn monitor on and will come on for about 5 seconds, then it goes off and the blue light turns yellow are green, does the same thing everytime
    Genius:
  • 2,120 Answers
You have a burned out Backlight Fluorescent Bulb.
Posted on Dec 20, 2008
When I turn on my computer the monitor turns on for about 3-5 seconds and then goes black. The blue light stays on and does not blink. If I turn the monitor off then back on it will again show the screen...
Had same problem, Monitor first turn on, backlight off after couple of minutes, off/on backlight off after few seconds.
Solution cut J503.
Found voltage OVPT (IC501,7) quite low (1.6V) this is the reference value for VSEN the over voltage value. By cutting J503, OVPT becomes 4.5 volt but is not depending anymore on the current through the lamps. Instead of the link J503 I solder 2x 1N4148 diodes which makes the OVPT not go below 2,8 volt. (diodes in series, cathode points to nearest board edge)
Oct 27, 2010 | Samsung SyncMaster 920NW Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
I have a HPw1907 monitor and it will turn on for about 2 seconds, and it turns off. The CPU is fine, just a problem with the monitor. Any way to fix this?
We have the same model of monitor and had the same problem few days ago. The monitor just goes black/turns off. I noticed that the power button has a yellow blinking light and cannot be turn on/off again using the power button. The CPU is working fine also. When I turn off the avr, the power button's light turns blue for a few second and you can hear a click sound from the back of the lcd before it totally turns off. My lcd monitor is over a year old now and is 110v or 220v capable. Mine was originally in a 220v, i just put it in 110v and the monitor was fixed.. Hope this can somehow fix your problem.
Aug 02, 2009 | HP w1907 LCD Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Problem with monitor
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
It sounds like you have bad capacitors on your powerboard or possibly a burned out transistor on the inverter.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
There is a chance one of your bulbs is creating a problem
Should the screen happen to light up all white, then your power board and inverter are okay and the problem may be in the video board.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
If it flashes on then goes off, it's in the power or inverter board.
ebaysbammbammfran
Sep 14, 2008 | ViewSonic VX2235wm LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
217 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
