Question about Empire GWT-25 Wall Mounted Panel Heater
Wall heater burners wont ignite
We have an Empire gas wall heater. I can light the pilot, but the burners don't ignite. Don't the burners light almost at once?
  • 69 Answers
You may have a bad gas valve
Posted on Dec 19, 2008
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Dec 14, 2015 | Heating & Cooling
Pilot lights but no main burner
Is there a way to check for gas pressure even if just a slight loosened connection to hear it then quickly re-tightened. Otherwise the main valve is not working as it should and will need to be serviced or replaced. Thats all i got.
Dec 02, 2011 | Empire Heating & Cooling
My empire wall furnace does not ignite. It has gas flowing because the pilot is light, i have changed the thermostat and wired it two different ways in case I reversed them. What is next? Could it be the...
It could be several things: Is the Control Knob turned from Pilot to ON? If that is the case, wait a few minutes after turning it to ON. That will allow the Thermopile to heat up sufficiently. Be sure the flame is touching the Thermopile. If everything looks correct turn up your Thermostat to higher than the ambient room temperature and see if the burners light. Remember to turn your Wall Thermostat down to the lowest temperature setting before turning the knob from Pilot to ON.
FYI - That Wall Furnace does not have a Thermocouple. It uses a Thermopile instead to generate millivolts of electricity to open the gas valve and maintain the pilot flame.
If it is the Thermopile, you can order it directly from Empire Comfort Systems, as well as download your Owners Manual at www.empirecomfort.com
Feb 04, 2011 | Empire GWT-50 Wall Mounted Panel Heater
Uh1200-fsp---pilot lit main burners wont ignite,fan runs,has new thermocoupler????
If you installed the new thermocouple, you may have overtightened it. It should be installed finger tight and only a quarter turn more. If it's to tight it won't allow the gas valve to open to light the burners. Be sure to turn the gas off, before attempting to work on the unit.
Feb 02, 2011 | Empire Heating & Cooling
PILOT FOR EMPIRE WALL HEATER WONT STAY LIT. I HAVE ALREADY REPLACED THE THERMOCOUPLE
are you sure the problem is with the thermocouple? is the pilot sharp and blue? it is unconnon for the magnet in a gas valve to go bad but it does happen. place the thermocouple in the valve and with it in front of you heat it with a match or lighter for 30 sec. now try and light the pilot quickly. if it lights the the problem would be the pilot, if not then the valve. is this a milivolt system or hydrolic t stat.
Jan 29, 2011 | Empire DVC-35 Wall Mounted Panel Heater
Have an empire wall furnace. Natural gas. Vent through the wall. My problem is that sometimes when it ignites, it makes a loud boom and I can see a flame flash at the top of the heat exchanger. I was...
Not sure what the problem is, but mine does the same thing.It also blows the pilot light out when it does it..Had several service calls, no luck...POS, don't buy another Empire heater....
Nov 09, 2010 | Empire Hight Efficient Direct Vent Wall...
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
Pilot light wont stay lit
You need to replace the pilot safety switch which is usually a Thermocouple. It is connected by a thin tube from the gas valve to a bulb near the pilot burner. It should be available at Home Depot or online.
Ray
Dec 17, 2008 | Empire ECS HB06M HearthRite Heater
Pilot on burners won't light
Pilot won't light - natural gas or propane. check for a spider web in the burner tube. check no dust in burner tube. check surface igniter is lit. if pilot lights check flame detector - may be a millivolt generator - it is a small capillary with a copper tip in flame path. no fire will keep the pilot valve closed. replace the generator.
Jan 29, 2008 | Heating & Cooling
Open Questions:
Heating & Cooling Logo
856 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
