Does not boot
You said same problem
How did you solve ?
  • 1 more comment
  • jatjag Dec 28, 2008
    Original_Re does not boot and It is RE Hp Laptop's
    PRESARIO ( V5000 ) v5308ca
    Attempting To Add Details__Clarify
    Sorry for the delay but was sick to resppond.
    Now when yoou start you know in the front shows souce of Power etc etc. I do not much about it but it does indicate it is trying to start__it does it for a good time than it dies out
    If you try to boot from the Bootable CD it does not. so with the Bootable rescue CD.
    By off___There is no by off meaning that I can click F2; F8 to either enter safe mode etc or BIOS
    It was working fine 2 days before it stopped.
    If you ask me I will try to answer
  • fergusonj May 11, 2010
    Did not solve this It appeared to be a motherboard overheat issue. The laptop boots then dies after time when it gets warm. Did not do the trick of cooling with invered can of dustewr to identify possible bad solder joint. some joker wanted 400 for replacement motherboard! replaced with new Apple model stayed away from crappy HP products.
    HP thinks they are GM... looking for chumps to buy inferiro products!
I have received a a problem in acer which is regarding boot up problem saying that windows can't start normally due to power failure
plz try by booting in safe mode, if the problem is not solved then try by booting in last good configuration, if still problem is not solved then you have to repair the operating system
Aug 17, 2010 | Acer Computers & Internet
Tip
Hard Reboot - To solve MOST problems
This is a tip on how to solve most of your PC problems when your laptop does not boot up.
1. REMOVE BATTERY AND AC ADAPTER.
2. PRESS AND HOLD POWER FOR 30-45 SECONDS.
3. CONNECT AC ADAPTER.
4. TURN ON.
5. ONCE BOOTED UP, PLACE BATTERY IN.
on Apr 26, 2009 | Acer Aspire 5500 5570-2609 Laptop
Screen is frozen. how can i re-boot or solve
take the battery out for 10 seconds, reassemble and go!
Jan 24, 2010 | LG Neon GT365 Cell Phone
My laptop will not boot. Says error occurred attempting to read the boot configuration data. Tried unplugging unit removing battery and put in operating system disc. None of this has solved problem.
this is a problem with the boot sector data ...the quick fix will be like this :
insert the operating system disk ...and restart ...choose to boot from the disk ..if it is not set to boot from the disk as priority ...it will not ask ya to press any key to boot from the disk ...in this case you have to go to bios by pressing del or F2 on start ...and there select the cd/dvd device as primary booting device ...press f10 to save changes and reboot...
it will start configuring your operating system again ....but after loading files ...when it gets to the first repair...just choose it ...(R) and it will get to a repairing sectore where it will ask for a command..
the proper command to solve your problem si : fixboot ...this wwill make it rewrite the boot sector and solve the problem ...
if you do not manage ...just let it reinstall the operating system ..but save the files before in another partition ...
Dec 21, 2009 | Acer Aspire 5610-4648 Notebook
In My PC Error Shows NTDLR File Is Missing,How To
Method:1
1.Make the first boot device as CD-ROM
2.Boot the system with windows(operating system cd)
3.go the first repair(r) option
4.once u got the command prompt change you directory to X:/i386
copy x;/i386/ntldr c:
copy x:/i386/ntdetect.com c:
note:x:(cdrom) drive may change
and then reboot the system.
method 2;
boot with the operating cd and go the second repair option and repair the operating system
Dec 02, 2009 | Gateway 500GR PC Desktop
Nokia n85 only show nokia and restart.
yes. this is the boot ic problem. pls. change the ic. this ic is stay near key pad ic. this is contains only 12 balls.
Apr 20, 2009 | Nokia N85 Cellular Phone
ERROR LAODING OPERATING system
Please boot in safe mode and uninstall the driver.
To boot inn safe mode:
- Start your computer
- Press F8 ( Just before it start booting into windows)
- Select safe mode
Apr 19, 2009 | Microsoft Windows XP Professional
Non allocatable error message on a cd made under winME trying to read in xp help please
When i turn on of my pc. then bios screen msg reboot and select proper boot device or insert boot media in the selected boot device. How to solve of this problem. pls .............solve tips for give me.
Apr 09, 2009 | Dell Computers & Internet
When booting from XP 'operating system missing'.Not booting from harddisk but booting from CD
plz check in bios your hard disk is detecting, then put the first boot device as hard disk.save and exit.
If the problem is not solved then you try with another hard disk cable.if the problem is not solved then you have to buy a new hard disk
Aug 08, 2008 | Computers & Internet
PC not booting!
please chat with me so that we can solve your problem in a better way...........thank
Thanks and Regards
Dilip Bagdi
Technical Associate
May 07, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
