Question about Chenbro SR107 (SR107-BLACK-550W) Extended ATX Rack-Mountable Case
Looking for documentation on how to set up drive cables from raid board with the sr107 server
  • 35 Answers
There is no documentation you can get but find an experienced technician to educate you
Posted on Dec 23, 2008
HP proliant DL380 gen4 PXE-E61, when trying to install redhat and solaris.
First, it's not booting from a CD or Hard Disk if you've reached that error. The 'last-ditch' effort to boot is to attempt a PXE boot from the network card, but your Ethernet cable isn't plugged in. Unless you know you've setup such a PXE boot server, you'll want to check the BIOS settings to be sure the CD-ROM is set to boot first, followed by the Hard Disc. Be sure you have Disc 1 of the Linux installation set in the CD-ROM Drive and reboot. If you don't get the install screen, you may have another issue (bad CD-ROM Drive, bad cable/controller, no power to CD-ROM, etc.)
Another note on the DL380, if there is a RAID controller, you'll need to setup the RAID before installing the OS. You'll want to make sure your hard drives are properly installed and aren't failed. The RAID configuration screen will verify the RAID status once it has been initialized, which will somewhat verify the drive status.
Nov 12, 2013 | Computers & Internet
Storage Drive 2: Drive slot sensor for storage drive fault was asserted
Sounds like you have a RAID. Take a look at the RAID management software and see if the RAID is degraded. If it is degraded you probably have a bad drive on your hands. Replace the drive and the RAID should rebuild. If it is not degraded. I would turn the server off for a sec remove all the drives and blow out the RAID carriage. I tend to do this anyway on our servers every quarter to keep the system clean and cool.
Hopefully this helps.
Oct 18, 2013 | Dell PowerEdge T610 Server (bqdwe2k1
Windows server 2008 raid setup on a dell poweredge 2850
2 drives indicates they are RAID 1, which are mirrored. 2 x 36GB = 36GB. This is an industry standard config. If you make any changes you will lose the array making it RAID 0 (no RAID - no longer hot swap), and or the complete loss of OS / data.
Instead make another logical drive for data storage. You need three or four drives to set up as RAID 5, again an industry standard config.
Make sure to back up in all instances. GL
Nov 14, 2012 | Dell PowerEdge 2850 3.8GHz 2u Server...
I have a server with a Serveraid 4H controller card, set up with two Arrays. Array B has 3 72GB drives set up as RAID 5. I would like to add 2 more drives to this array. Is this possible or do I have to...
I am not familiar with your RAID controller card but as long as the controller can see two additional drives, it shouldn't be difficult to add two new drives to your exisiting RAID 5 configuration.
You will probably need to reinitialize the RAID configuration for discs to copy all the parity information so you should refer to the documentation on re-initializing the RAID.
May 25, 2012 | Computers & Internet
I cannot get the 2 x 4500Gb SATA drives to show up in the BIOS of a intel s875wp1 board. It is an older board and had the RAID setup in place - I just want the 2 x SATA drives as normal so turned off the...
ATA/IDE has nothing to do with SATA. Ignore.
Try plugging in the drives into the non RAID sata ports on the motherboard. I think when you disable raid you also disable the raid ports. You should have another set of sata ports on the motherboard, probably a different colour.
Nov 26, 2009 | Intel S875WP1-E Server Board Motherboard
1 Adaptec RAID 3085 cause parity error in server while 2nd don't!
I'm thinking you should be checking the drives. If one of them is failing, you will get parity errors.
Picking apart parity problems TechRepublic
Mar 04, 2017 | Acer Altos G530 Server
Scsi raid with battery backed memory for pweredge 2550 server
if my memory serves me correct i think this server uses a onboard (3di) card it is set in the bios to use the raid configuration, under integrated devices .make sure this is so ,as it boots press f2 key to enter.If this is so exit.next step is to shut the machine off pull the drives away from the backplain not completly out. Power up if it starts laoding the raid configuration,once the scan is complete it will give you a container not found error,now here is what you can do go in i think its control m or r,anyway look at the configuration and what raid you set it up for.write down the drive number 0-etc.ok the next move is the raid key a little device that sits on the motherboard beside the raid dimm reseat this,now you may want to replace the raid dimm or if you have a exact match for troubleshooting purposes you may try this.
Good Luck
Feb 05, 2009 | Dell PowerEdge 2550 Server
Poweredge 1600sc cant see other 4 drives
HI thanks for reply. i must say im new to this raid stuff. i was given the server by my coworker because he could not get the other drive to show in windows. he got fustrated and gave it to me. so i tey at home. ok here is what i have.
Dell poweredge 1600sc. it has two gig ram. I open the case andther it has one primary hdd and four other hdd connected on one ribbon to the board. it had windows server 2003 all ready on it. I was in the set up (ctrl +m) and i saw the drives say ready. i hit the space bar to set array. after i did that it say i had to initlize it before i reboot. now the drives say online. i boot into windows and the drives are still do not show. am i looking in the right place. i know. im stupid. go ahead and laugh.
plus is there a good place to lean this raid stuff. thanks. nezza
Aug 05, 2008 | Dell PowerEdge 1600SC Server
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
PowerEdge 1750 can not recognize the Local Harddrive
I think you need to provide heaps more info, like what operating system etc.. Have you tried to change the interface to another port eg if IDE, then move the cable to the secondary or if sata test the drive with another cable/port.. Have you tested the drive in another computer? OK, if it's scsi, then does the drive need a termination? Most scsi drives need a dongle or a terminator to allow them to be recognised.
Apr 26, 2008 | Dell PowerEdge 1750 Server
Chenbro SR107 (SR107-BLACK-550W) Extended ATX Rack-Mountable Case Logo
113 people viewed this question
Top Chenbro Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Chenbro Computer and Internet Expert? Answer questions, earn points and help others
