Can not remove the rest of the TV stand
Have recently wall mounted a Panasonic TX-32LXD60, but can not remove the rest of the TV stand. Its the part of the stand that allows the TV to swivel. There is a tiny hole which may have a grub screw, but have tried several alum keys but can't release it.
I am the owner of the Panasonic TX-32LZD60, and finally managed to solve the problem myself.
So for anyone else out there with a similiar problem, you need first remove the two screws at the back of the TV which are low down. Take of the small plastic casing. Underneath you will see two rows of a total of 8 screws, which go through a black metal plate. Remove these and the stand will slide out. Not bad for a girl!!
Posted on Dec 20, 2008
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
How to remove a stand
you have 4 screews to remove on back of your tv. 2 each side of connector panel
Apr 29, 2010 | Televison & Video
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
Cant get the stand off a panasonic 32 inch TX 32LXD60 to put on the wall
TX 32LXd60
Lay the tv face down on a flat surface. Do not scratch the screen ! Use a cloth.
Remove the 4 screws above the stand. Pull stand out. Replace screws.
You can get Operating Instructions from;
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
enter the model number- click search- and download the Operating Instructions . The Operating Instructions will illustrate the stand.
Apr 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
How to remove stand from panasonic tv model no tx-32 l m d 70
Place tv on its BACK,with the screw holes underneath.Remove the four screws,remove stand,and turn tv over to rest on the sceen (on top of a towel)or some other cloth so as not to damage the screen,and replace screws.The reason for placing the tv on its back when taking out the screws,is that,unless you have a magnetic screwdriver when removing the screws the are difficult to remove as they are deeply recessed.
Apr 09, 2009 | Emerson RP6248 AM/FM/TV Radio
How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Jan 31, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic Viera TX-32LXD60 on screen display
On your TV remote, to the right of the "0" is an "i" - press it!
May 22, 2008 | Televison & Video
Televison & Video Logo
940 people viewed this question
Top Televison & Video Experts
