Question about GE JVM1440 Microwave Oven
My JVM1440 sometimes runs when I shut the door
Sometimes after my microwave finishes and I take the food out, when I shut the door, it automatically starts up again, even though the timer is complete. I'm not sure if it's just the fan running or it it's actually heating. This unit is just over 1 year old.
  • nlorntson Jan 20, 2008
    My JVC1340WW002 starts up when we shut the door. None of the buttons work when it is running like this. The turntable does not rotate. The unit does not appear to heat.
    This happened out of the blue today.
    Occasionally if we open and shut the door it behaves but even this is sporadic. I see this is likely either a bad door switch or a bad board of some sort.
  • GE Master
  • 9,098 Answers
It's almost certainly a door switch going bad or a loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, info and a text file which helps in diagnosing and repairing door switch problems at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here:
Posted on Mar 29, 2007
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
Intermittent heating
From the description you have a bad latch switch on the door caused by build up of food particles or ware.
Mar 05, 2012 | Bosch HMV9305 Microwave Oven
Mine is a similar problem - light and fan BOTH stay on when the cooking/heating finishes! The door remains closed and the food/beverage cooks. However, when it's finished the light remains on and the
There are a number of interlock switches that the oven door activates when closed, sometimes one becomes defective causing the main fuse to blow in the microwave or continue to run when time is up.
Nov 11, 2011 | Microwave Ovens
GE JVM1440 just stopped working.
This is almost always the primary interlock (bottom door switch) or its mount is loose or cracked.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
It's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Jan 31, 2009 | GE JVM1440 Microwave Oven
Whirlpool over the range microwave
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
You can find helpful exploded view diagrams and order parts by entering your full model number here:
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
Oct 18, 2007 | GE JVM1440 Microwave Oven
Slow turn, hot food
underneath the deck is a geared motor that turns the platter. check for non lubricated bearings or slipping gears.
Aug 22, 2007 | GE JVM1440 Microwave Oven
GE JVM1440 Microwave Oven Logo
96 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
