Question about Logitech Harmony 785 LCD Remote Control
Locoal broadcast on chanel 3 and i have no switch to change output to chanel 4
    Problem Solver:
  • 7 Answers
First does your TV have a remote control? If it does then you have to change the output in there.If you have a VCR try using that if not then you can buy a switch at Radioshack.
Posted on Dec 19, 2008
  • lenz2780 Dec 19, 2008
    thats in the onscreen menus
How do you hook up cords to cable box & television
WELL IT SEEMS U HAVE TWO PROBLEMS :
1ST YOUR rF SIGNAL IS NOT GETTING THRU , THIS IS A ROUND CABLE WITH A SCREW ON END TO IT , THIS ONE MUST 1ST COME INTO YOUR HOME AND GO TO CABLE BOX , THEN LEAVE OUT OF CABLE BOX AND ENTER VCR THEN LEAVE OUT OF VCR AND GO TO RF INPUT OF TV ( HAS TO BE HOOKED THIS WAY WONT WORK ANY OTHER WAY) SET OUTPUT OF VCR TO CHANEL 3 SET OUTPUT OF CABLE BOX TO CHANNEL 3 SET TUNER OF VCR TO CHANEL 3 , AND LAST SET INPUT OF TV TO rf CABLE ,CHANEL 3 , NOW YOU CHANGE CHANELS ON CABLE BOX only
2ND YOUR DVD PLAYER HAS NO RF OUTPUT SO YOU NEED TO CONNECT BY ONE OF THESE MEANS (HDMI, RGB, COMPOSITE) ALL THESE REQUIRE A DIFFERENT CABLE YOU DECIDE , THERE HOOK UP IS PRETTY MUCH ONE WAY SO I WONT ELABORATE ON EACH METHOD , BUT TV NEEDS TO BE SET TO CORESPONDING INPUT TYPE YOU DECIDED ON
Nov 11, 2015 | Magnavox DV220MW9 DVD Player VCR
How do you set cable to 16:9 output?
Different channels are broadcast in different aspect ratios, depending on the network and the show(s) being broadcast. Many older show are still broadcast in the 4:3 ratio to avoid distortion. Currently, there is nothing in the broadcast signal that tells the TV what aspect ratio to use. Therefore, TV remotes have a selection button (mine says "P.SIZE") that allows the user to change the aspect ratio to optimize the viewing experience.
Sep 05, 2014 | Hitachi Televison & Video
What chanel does it need.to be on for satilite
Usually channel 3 or 4. Depends where you are from and if one of the local stations are broadcasting on that channel.
Jan 05, 2012 | LG Televison & Video
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
How to connect a 1999 zenith TV to a cable box and
Connet the output of the cable box to the DVD player and the TV out output of the DVD player to the TV (TV must be tuned to Channel 0, Chanel 3 or 4). You should be able to use the remote to switch between the DVD signal and the cable signal.
Hope it helps.
Sep 08, 2009 | Zenith A25A23W 25" TV
Don't know how to change from cable to antenna
on the back of your set
there may be a small switch someone with 2 or 3 different options
Jan 20, 2009 | Sony KV-24FV12 24" TV
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
VCR model VHQ 41m
I have not heard of one that doesn't have the selector switch to change to 3 or 4, Could it perhaps be in the front behind a door or just somewhere else?
Aug 01, 2007 | Quasar VHQ401 VHS VCR
Logitech Harmony 785 LCD Remote Control Logo
69 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
