Question about Linksys Wireless-G WRT54G Router
How to secured wlan linksys router without format disc
Can I security enable my linksys 2.4ghz router without disc as laptop crashed I've reset the router to factory settings but laptop will not give me access without user Id and password.
  • Linksys Master
  • 6,487 Answers
Putting pasword
wirelessl ?
Many households have unsecured wireless networks, which can lead to hackers as well as leaks in confidential information. However, you can password-protect your wireless network by taking some basic steps.
Determine your network IP address by navigating to the "Start" menu and selecting "Run." In the Run dialog, type "cmd" (without quotes) and click "OK." The Command Prompt dialog opens. Type "ipconfig/all" (without quotes) and press "Enter." The command prompt will display a list of data for you network, including your IP address. Launch a Web browser and input your IP address in the address box. The control page of your router is displayed. Refer to the manual that came with your specific router on the manufacturer password/user name to login to your network. Usually the User Name is "admin" or "password" and the password is either "admin" or "password." Sometimes these fields are left blank. After logging into the router you can access the administrative functions. Within the administrative functions, navigate to the security settings. Within the security settings, you can change the username and password to log in to the router. Disable the router's remote administrative functions. Remote administrative functions allow anyone using the Internet to access your router. To be more secure, disable these options. The only reason to enable them is if a network administrator isn't always on location. Change the network's name. Your router comes with a default network name like WLAN or Linksys. These names are referred to as SSIDs. You want to change the name to something that you will recognize, but others won't associate with you. If your name is John, don't call your network "John's Network." Enable encryption and enter a password in the appropriate field. Wireless routers use several types of encryption, including WPA2, WPA and WEP.
At the time of publication, WPA2 (Wi-Fi Protect Access 2) is the most secure encryption format available on some routers. But you can't use this encryption type if your router doesn't support it. WPA (Wi-Fi Protected Access) is recommended if WPA2 isn't available on your specific model. WEP (Wired Equivalent Privacy is the least secure of all the encryption formats and is relatively easy to hack. If you have no other choice, use at least WEP encryption. Some protection is better than no protection.. Record your password and settings for future reference. If you lose your password, you can reset your wireless router to the manufacturer's default settings by pressing the router's "Reset" button, usually found on the back of the unit. Remember to re-secure your network after a reset.
How To Secure Wireless Networks
http://www.pcmech.com/article/how-to-secure-wireless-networks/
Apr 18, 2013 | Computers & Internet
Tip
Enabling Wireless security on Linksys routers.....
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then unchecked “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
If this is a Helpful tip Thumbs Up is appreciated. Thank you
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
LOGISYS ROUTER
1 Press and hold the reset button on the LinkSys router for 30 seconds. The location of the reset button varies depending on your model, but it is usually located in a small pin hole on the side or back of the unit. Insert a straightened paper clip into the hole until you feel resistance. A hard reset occurs and the router is restored to its factory defaults.
2 Log in and reconfigure the router following the hard reset. Connect a PC to an Ethernet port on the router. Open a Web browser and navigate to http://192.168.1.1/. A popup box opens, prompting you to log in. On older LinkSys routers, leave the username field blank and type "admin" for the password. On newer routers, the default username and password are both set to "admin".
Go to the Management tab after you've logged in and set a new administrator password. For maximum security, choose a password comprised of random letters and numbers. This type of password is secure because it's impossible to guess.
Enable WEP or WAP security so that nosy neighbors cannot tap into your wireless network
BMW Custom Parts
Jun 06, 2012 | Linksys Computers & Internet
Resetting password on a Linksys Router.
Hi there! :) just follow the steps to reset your router hope it works! :)
1.Press and hold the reset button on the LinkSys router for 30 seconds. The location of the reset button varies depending on your model, but it is usually located in a small pin hole on the side or back of the unit. Insert a straightened paper clip into the hole until you feel resistance. A hard reset occurs and the router is restored to its factory defaults.
2.Log in and reconfigure the router following the hard reset. Connect a PC to an Ethernet port on the router. Open a Web browser and navigate to http://192.168.1.1/. A popup box opens, prompting you to log in. On older LinkSys routers, leave the username field blank and type "admin" for the password. On newer routers, the default username and password are both set to "admin".
3.Go to the Management tab after you've logged in and set a new administrator password. For maximum security, choose a password comprised of random letters and numbers. This type of password is secure because it's impossible to guess.
4.Enable WEP or WAP security so that nosy neighbors cannot tap into your wireless network.
Oct 02, 2011 | Computers & Internet
I have a Linksys wap54g wireless router and it has just started dropping the signal. My DSL modem that it is connected to is working fine. I have powered off and reset multiple times but without much...
If you recently started using cordless phones that use the 2.4GHz frequency spectrum, this can cause your WiFi signals to drop-out.
Other forms of interference can come from:
  • Microwave ovens
  • Bluetooh enabled devices
  • Other nearby WiFi routers/APs using the same channel
Additionally, if you haven't secured your router using WPA/WPA2 security, a neighbor may be leeching off of your WiFi network and download files on P2P networks. This would cause your router to become saturated with traffic and appear to crash. Make sure that your router is properly secured with WPA/WPA2 security (not WEP, since it can be cracked within a few minutes) and make sure that you change the admin password.
Dec 24, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
My WRT300N Linksys router shows all lights, I've hit the reset button onece, but I can not get online without plugging the cable directly into my computer.
Since you hit the reset button on the router, it will go back to default settings.
By default, the SSID is linksys and the wireless security is disabled.
So on the wireless network connections on your computer, you should see linksys and then just connect to it.
However, it is advisable to change the default SSID and to enable the wireless security.
Follow this link to change the SSID.
Follow this link to enable wireless security.
Dec 30, 2009 | Linksys WRT300N Wireless Router
Does not save wireless security settings
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
5. Restart your PC
Nov 15, 2009 | D-Link Vonage-enabled Wireless Router...
Securing my wireless
if you are talking about the wireless security, by default it's not enabled so you need to enable it by going to the router's setup page. here's how: open a web browser (e.g. internet explorer, firefox etc) then type http://192.168.1.1 on the address bar. it'll promt you for the username and password, leave the username blank and type admin (default password)on the password. you will then be prompted with the linksys page, go to the wireless tab then look for the wireless security subtab. there you can enable your wireless security.
hope this'll help you and just ask me if you have other concern
ciao!
Oct 21, 2008 | Linksys A+G WRT55AG Wireless Router
How to secure conection to linksys router
Are you trying to secure the wireless connection?
Jun 17, 2008 | Linksys Wireless-G Broadband Router
WLAN connection
make sure that your wireless network card works.go to the settings of your router and set: wireless network mode:802.11b(or what your car supports) wireless network name:name Wireless SSID Broadcast:enabled Security Mode:wep wep key:write something create a new connection to your laptop with the above settings
Oct 04, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
108 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
