Question about Nokia 3100
The screen is not working and i would like to copy the contacts to the sim
    Novelist:
    Scholar:
  • 111 Answers
Your LCD cable is bad and need to be replaced or if you be able to check by open the case to see whether the cable is connected firmly. Usually, loosing connection between cable and mainboard is first point to check. If it is still connect tightly then your LCD cable is bad. Please view the link below for the instruction how to open the housing and from there you will be able to troubleshoot your LCD connection: http://uselessinfo.pwp.blueyonder.co.uk/dismantle3100.htm Good Luck
Posted on Mar 31, 2007
  • Joseph Dao
    Joseph Dao Mar 31, 2007
    Dont't worry about your SIM card Contacts. You can do this by first install the sync software of your Nokia Model into your PC. Once you have done then use the Nokia Data Cable to connect your phone to your PC. Your PC will reconginze your pc as removable drive or handheld device then you will be able to view your phone contents included your contacts then you can move all of your contacts into your PC temporary. This information I added to my first solution above but if you can fix and replace the LCD to me is the easiest way then you don't worry about moving your contacts around. I hope this help.
  • Joseph Dao
    Sorry. I mistyped one word in the third line. I supposed to write: Your PC will recognize your phone as removable drive so please adjust it accordingly. Sorry once again for my typo error.
How do I trasfer data from my phonebook to the sim in Samsung Corby?
Hi there go to your phonebook contacts at the bottom of screen where it says more press it then press copy contacts it gives the option phone to sim or sim to phone you need to press phone to sim then you can choose to copy indevidual contacts or all when youve chosen which contacts press copy at bottom of screen and your done hope this helps if it helps can you please give me thumbs up thanks
Feb 13, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I bought a new Xperia X10 and i want to copy contacts from my old phone. I copied all my contacts from old phone to the Sim. My question is how can i copy the contacts from Sim to my new X10?
Yes indeed you can copy your sim contacts to your X10
Just insert the sim into your x10.
Turn on the handset
Open main menu by tapping bottom of screen. Or touch bottom of screen and drag finger upwards.
Find "phonebook" and tap that.
Now your phone book is open Press the Bottom LEFT button on your handset not the screen the actual button.
A menu will pop-up so tap the "More" option
Then tap "Import Contacts" from this menu
Then tap "Sim Card" from the new pop-up.
The rest should work for you.
I hope this helps and I hope you enjoy your new phone. :)
Jul 18, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Screen is damaged, need to tsf contacts to sim
select menu then scroll down twice .the select ok .then scroll down 5 times then press ok 2times and ur contacts will be stored to ur sim card
Apr 16, 2010 | Nokia 6230
My N95 screen has gone black, everything is still working I just cant see anything. All my numbers are saved to the phone not the SIM, anyone got any idea how I can get them off??
Plug the AV television output cable that should have been included with the box your phone came in.
Now plug the cable into your phone and connect it to your TV.
The cable allows you to use your TV as an external screen and from there on you can save your contacts to your SIM card. You can now see and use your phone but while using your TV as a screen.
Now to copy the contacts from the phone to the SIM card, just go to Contacts > mark the contacts you want to copy to your SIM card and then press Options > then scroll down to Copy and it will allow you to copy to either SIM directory, copy to Mass memory or copy from Mass memory. Just select Copy to SIM memory and there you go !
Hope I have been of assistance to you,
Cheers :)
Feb 14, 2010 | Nokia N95 Cellular Phone
Screen going blank.switches off.
steps to copy phone to sim
- press down soft key once
- then press up key two times & select button
- then again press up once & select button
- then press down key 5 times & then select 3 times
- wait for 2-5 mins your phone contacts will be copied to sim
vote me if u get this
Jan 04, 2010 | Sony Ericsson K850i Mobile Phone
Copy contact from phone to sim with cracked screen
If you have a cracked screen can you still read it? If not you'll have a problem copying the sim.
If you can-
Go into menu and select "contacts" Select "options" key down to "advanced" Select key down to select "copy from SIM" or "copy to SIM" function which ever you need.
Nov 20, 2009 | Sony Ericsson K800i Cellular Phone
How do I move my contacts from the sim card to the phone?
You can go to Menu > Contacts > Names > Options > Copy.
You can copy names and phone numbers from your phone's contact
memory to your SIM card memory, and vice versa.
Sep 13, 2009 | Nokia 6230i Cellular Phone
Blank screen w200i, need to copy contacts to sim
put ur sim in some other phone . look if some contacts are copied by mistake or u can get help from ur
sim network provider see if they might able to send ur contacts back.
Jun 11, 2009 | Sony Ericsson W200i Cellular Phone
My screen is blank!
try this one. just go to contacts then just look for copy all then there is a message that will appear that says copy all to phone or copy all to sim card. just try and try to fix the phonebook of your phone you will see it.
Feb 25, 2008 | Cell Phones
Nokia 3100 Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
