Question about Kenmore 62702 Microwave Oven
Mokes when re-heating food in plastic microwavable dish
Smokes when re-heating
  • Kenmore Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
Posted on Dec 21, 2008
Wall of microwave oven is burned any way to clean it?
If it doesn't clean with dish soap, particularly where the microwaves come through the place on the right side that is plastic,then it is pooched. The microwaves will not get through to the heating area and reflect back to the magnatron. The thermal switch will open and the unit will not heat. or get hot and the food will be under cooked.
Feb 08, 2018 | Microwave Ovens
How do I reheat frozen lasagna
Microwave ovens are not meant to cook food, except in a very few situations. If the lasagne has already been cooked before it was frozen, then you'll need to weigh and to reheat it in accordance with the manufacturer's instructions in order to ensure the dish is heated through, though it's better to use a food thermometer.
The temperature you should aim for throughout the dish is 83C. Only at that temperature can you be sure that any bacteria in the dish will have been severely depleted.
Feb 21, 2015 | Microwave Ovens
My Kenmore Microwave slowly heats but mostly the dishes vs. the food. By the time the food is warm enough, the plate or mug is practically baking. The microwave is only 4 years old, so I can&#39
Sounds like you don't have proper microwave-compatible plates or mugs. Must have lead in them, or in the paint (!?!) Try a plastic plate or even a paper plate. I can't think of anything that would make the microwave oven do that, UNLESS it's a microwave/convection oven, in which case, the convection heater must be coming on whenever you are trying to just use the microwave function.
Sep 24, 2014 | Kenmore Microwave Ovens
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
Smoke and burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
Dec 31, 2013 | Sharp R-1610 Microwave Oven
I placed food in the microwave over to heat for 19 seconds, when it was finished I smelled smoke coming from the oven. The food was fine. I unpluged the oven. I tried it a couple of days later, it...
the smoke probably came from the heated food. try using it next time with different kind of foods and also try it to the same kind of food that produces smoke but observe carefully what will happen.
Dec 29, 2010 | Emerson Microwave Ovens
We put a plastic jar with a very small piece of foil on the rim and the microwave started to smoke. it might have run 30 seconds before we noticed it making a funny noise. it is a 1200 watt inverter
Hello Dwight,
You may have damaged the microwave. Since the oven cavity is a tuned cavity, introducing metal into it can wreck havoc on the magnetron (microwave generator itself).
Did you happen to notice if the smoke was from the plastic jar (plastic heating up from the high temp of the foil ring), or if it was the actual microwave smoking (and not blowing smoke out of the oven cavity from the plastic jar)?
Sep 14, 2010 | Panasonic MCM INVERTER
Microwave doesnt heat, power is on fan is working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
klgjlgk
Jul 06, 2010 | GE JVM1540SMSS Microwave Oven
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
Kenmore 62702 Microwave Oven Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
