Question about Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000
No electrical output or no electricity
I purchased this unit at Sam's club one year ago. Started it and realized it had no voltage output. After reading the manual, I believed my problem was that the generator needed to be re-excited. Today, one year later, I called them to ask for proper procedure and they told me that my unit was different that the one shown in the manual and mine doesn't ever need to be excited. Anyone have the same problem and if so, what part needed to be replaced. I ask this because the company went bankrupt in March. Just my luck.
  • 3 Answers
Demand sams take it back, or give you a working one. They sold it, they need to handle their end of the deal. If they don't back there product, put it in the news.
Posted on Dec 19, 2008
My Yamaha Ef2400iS inverter shuts off when I use my 3/8th electric drill. This problem started last fall. I could use the drill and portable saw, not at the same time, since the inverter was new three...
yes, the problem is that electronic/electrical components age with use. especially voltage regulators and switching transistors. as they age they can no longer sustain the current you are demandiing from the unit. the units are designed to run in the middle zone, not at full maximum load all the time, if you do that you will weat it out quicker. Always buy a power supply that is double your intended wattage and it will last many years. Hope this answers your question
Mar 21, 2011 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Reliance electric water heater - A 95 [1995] Model 5 40 / 3500 W Max. - 240 AC Volts. Checked upper element and thermostat [fine]. Lower element and thermostat have lot of corrosion due to...
The salesman at the hardware store should be able to confirm my answer.
Match up the voltage, wattage and thread size and you should be good.
My element burned out two years ago and aside from draining the water, the job only took a few minutes and I was back in service.
A week ago our oven stopped working during cooking. I had my husband flip the circuit breaker and it still didn't work. 15 minutes later we were able to get it to work again. Today i started to preheat...
Had similar problem with my oven.
Turn off the breaker to the oven/range and remove the panel which exposes the controls. You will probably find a burned spot on the pc board.
Mine was where a spade lug plugged a wire to the board and caused by a loose connector at that lug. I hard wired/soldered the wire to the board (new board was $200+) and the repair lasted several years.
Sep 19, 2017 | Jenn-Air JES9800BAS Electric Kitchen Range
I have a cheese dispenser from AFP Dispensers, Model is Sierra and I do not know how to work it. PLus I need to know what types of cheese it dispenses.
Hi there. It dispenses nacho cheese sauce.. you can call your local rep. to order and get particulars. contact your local AFP sales representative for details, or call 866-239-8475
Aug 06, 2009 | Kitchen Appliances - Others
My Coleman Powermate 6250 generator has no power output. After the carburator was cleaned, I flashed it. A voltage meter shows there is power being generated, but none so to light a light bulb. What to do...
Take the cover off and flash the rotor again with a 12 volt battery. Positive lead goes to the top or right side brush. Negative to the other brush. Just touch it on, then remove it, and check for power at plugs.
If that doesn't do it, change the AVR (voltage regulator)
Aug 05, 2009 | Coleman Powermate Premium Plus 6250W...
Singer 7422 power output
The electrical specifications are as follows:
220 - 230 V
Total 65W
Enjoy your machine
Dec 04, 2007 | Singer 7422
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000 Logo
311 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
