Question about Insignia LCDTV26 26 in. Television
When I press tv the description says I select the atsc or ntsc
Tv source. I don't see these choices (atsc or ntsc). Should these choices appear when I press tv.
  • Insignia Master
  • 5,568 Answers
NTSC is the earlier and soon-to-be extinct US standard, ATSC is the coming one for HD and is digital instead of analog in its signal coding. Most later sets will determine what is available and switch accordingly. Many stations are running tests at random now for a few minutes to let you know if your set is HDTV 'ready.' Check with your local station schedules to see if they are listing times for this test signal.
Posted on Dec 23, 2008
How to activate the tuner setu
Check which input is the current one. You can't access the tuner setup unless the input is set to TV. There should be a Source or Input button on your original remote. There may be a matching button on the TV. Please add a comment with the model of the TV, if you would like me to check where the Input or Source might be. (If you have a universal remote, it may or may not match this feature with the code that makes most of the TV features work.)
Note: some TV models were sold without tuners or only NTSC (analog tuners) depending on their size and release date. ATSC tuners were only mandated in 2005 for 36"+ TVs in the US. For these older TVs, you may need an OTA tuner (or ATSC to NTSC converter) box.
I hope this helps.
Mar 29, 2018 | Pioneer Televison & Video
I have a DMR-ES35V DVD/VCR. Yesterday I recorded a TV show on the VCR and when I tried to play it back there was only snow. The TV is also Panasonic (TC-P42S1).
The DMR-ES35V only has an analog tuner (NTSC). Most TV channels now transmit in digital format (ATSC). Since the remaining analog stations are associated with low-power tuners, the tuner may not have picked up the signal. If you have an aerial antenna directly connected to the DMR-ES35V, it probably didn't find a signal. In that case, you need an OTA ATSC to NTSC converter or a stronger signal for a station giving an NTSC signal.
However, if you tried to record from a set-top box (cable/ OTA ATSC to NTSC converter), then check your connections. Several cable boxes will not transmit the analog signal if it is also sending a HDCP signal (high definition copy protection) to another monitor. (Thus if the TV is connected to a set-top box by an HDMI cable, no analog signal is available on composite video or RF outputs.)
Please add a comment to indicate what your TV source is and whether the source is connected to the DVD/VCR and TV separately or in a daisy-chain fashion.
I hope this helps you identify your recording problem.
Mar 05, 2018 | Panasonic Televison & Video
Is the Rca true flat digital
I'd need the model number to tell if the RCA TV has a digital (ATSC) or analog (NTSC) tuner. The mandate for inclusion of the ATSC tuner depended on the size of the TV and the year of manufacture. Small (<25" diagonal) TVs didn't need to have an ATSC tuner when they were built until 2007. The older TVs could still be sold with a "cable-ready" or similar NTSC only label. (The 32"+ TVs had to have the ATSC tuners in 2005 and the mid-size TVs had to have the digital tuners in 2006.)
For example the 27F530T was manufactured in 2003 and only has a NTSC tuner. However, the 20F424T was manufactured in 2008 and does have an ATSC tuner.
I hope this helps.
Aug 07, 2015 | RCA Televison & Video
How can i tell if my tv is digital
The iLo IWT3206 TV provides two built-in -- or integrated -- TV tuners: a National Television System Committee (NTSC) tuner and an Advanced Television Systems Committee (ATSC) tuner.
While the NTSC tuner allows iLo IWT3206-viewers to receive analog, free-to-air TV broadcasts, the ATSC tuner allows viewers to receive digital TV broadcasts via a cable or satellite provider.
The benefit of having an integrated ATSC tuner is that it negates the need for a separate cable box or satellite receiver, which can take up space.
Oct 24, 2013 | iLO IWT3206 TV
It is used in india or not
Hello
This set RCA HD52W59 is not compactable with Indian TV tranmission system. India had s adopted PAL-B [Phase Alternating Line], system for both transmitting and receiving. This RCA set is intented to use with ATSC system, ie, it is meant for use in US only. If you get this to India, you have ot buy one RF converter, capable of converting PAL to ATSC & NTSC. You cannot get this converter from Indian market, as it has no use with Indian TVs. You have to buy it from any other source. You can see NTSC of ATSC recorded discs, and player which has these system compactabilities, but not able to receve either cable of on-air Inidan TV transmissions. OK.
Aug 27, 2011 | RCA HD52W59 HDTV Projection Television
Is the tuner built-in ATSC, or NTSC?
Your tv tuner is set to function on both NTSC and ATSC. See below for the reference
NTSC (National Television System Committee) is the analog television broadcasting standard used widely in North America. It is referred to as a 525-line standard, but actually displays only 480 lines. NTSC is to be replaced with new DTV (Digital TV) standards in the coming years.
ATSC (Advanced Television Standards Committee) creates the technical standards for the US digital television system (DTV). These standards are expected to be used in most new televisions, as the US television system shifts from analog to digital.
Nov 10, 2010 | Toshiba 57H84 57" Rear Projection...
Cant use scart socket
Press the "TV/AV/PC" button to display the choice of input sources, move to the required choice (SCART in your case) using the channel up/down buttons, then press the volume + or - button to selectyour choice.
Feb 18, 2010 | Televison & Video
Vhf is not picking up signal, no image
Well since all TV is now broadcast in High Definition that might be why you are no longer able to tune in a station. You will need the converter box.
Aug 19, 2009 | Casio Televison & Video
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Insignia LCDTV26 26 in. Television Logo
93 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
