Question about JVC AV27F476 27" TV
I have a JVC television and it periodically turns from color to black & white. Sometimes it returns to color on it's own and sometimes you have to hit the side of the TV and it will come back that way.
  • stevenhippen Feb 14, 2010
    Thanks! Will post how it went after I work on it. Very good directions and easy to understand!
  • 1,476 Answers
This is a common problem when electronics get older. You have a bad solder joint on the video IC. If you can solder you probably can fix this. Unplug the set. Remove the back. Remove the main board. Looking at the main board find the IC that has a small shiny metal can which is flat on two sides with rounded ends about 1/4 inch thick. Usually the boards are marked as to what parts do. If you see an area marked video that would be the best place to look. The IC will be relatively large. Probably about 64 pins. Should have a number on the top which begins with TDA*********. You will need a soldering iron of about 35 watts with a good conical tip with a small point. Once you locate the IC inspect it with magnification. You will probably see hairline cracks around the leads which go through the board. Resolder all the leads being careful not to bridge any pins. If you do happen to bridge any remove the solder with solder wick and resolder. Look at a other leads in this area and resolder any suspicious connections. If you have the time just resolder all components in this area. When you are sure you have all the bad connections reassemble unit and test. If all went well you should have a reliable unit. If the problem persists resolder all connections on the board. After that if the problem persists replace the TDA******* IC. This should solve your problem. Let me know how this works out or if you need anymore assistance.
hardrocko
Thanks for using FixYa
Posted on Feb 14, 2010
Ocasionally, after the TV has been on for a while, the red color just disappears leaving the picture with a pronounced yellow tint to the colors.
First check all your input cables at both the source & the TV. try wiggling them at the units to see if problem may be in the cable or possibly in the PCBoard. You may have to replace the MAIN PCBoard. I cannot give you the part# since you didn't give your brand or model#.
To locate the part# you might go on line to the manufactures support site.
May 14, 2015 | Televison & Video
Why can't I get a color picture when using the component connection to my JVC BC50R LED TV?
Because your component input typically can not handle RGB, or CMYK color palets. So you end up with a black and white, or sometimes, yellow and black, image.
Jul 13, 2014 | Nintendo Wii Console
My Coby LEDTV 1926 blinks red, green, blue, white, and black. Is there anyway to fix this?
Sorry I can't help, but mine does the same thing sometimes. It'll work fine for awhile, then no picture, but goes crazy and flashes one color at a time across the whole display, very brightly. I have it connected to RCA inputs, so I don't know if it would happen using the antenna input, but based on your experience, I suspect it would. I never got around to calling tech support, and my return period ends in two days, so it's going back to the store tomorrow.
Oct 30, 2011 | Coby Televison & Video
My sony 29'' color tv turned black and white.color sometimes flash on the screen.video and sound is normal.pls help
     If your TV colors get black and white with flickering then there must be a problem of cold soldering(Loosing) and it can be remove from resold, Resold in video section and problem will be solved.
     Thanks.
Jan 14, 2010 | Sony Televison & Video
Television
there will be 2 convergence ICs that you can access from the front. take the grill off in front(screws behind door and on side in back of tv)and take the panel off. then the board right in the front with the black heat sinks is the convergence power board. take the board out or position it comfortably and replace the 2 large ICs(stk392-110) and any burnt resistors you can see. after fininshed check alignment in the regular tv menu.
Feb 18, 2008 | JVC AV-48WP74 48" Rear Projection...
COLOR GOING OFF AN ON (COLOR TO BLACK AND WHITE)
see the back side of the cabinet for main screws, open them to get inside the cabinet
there you can find the main curcit board.. there look for bad solder joints
good luck
cheers!!
Feb 08, 2008 | Toshiba 55H70 55" Rear Projection...
COLOR PROBLEM
your tv need a reheat.reheat from video chroma to crt board
Oct 16, 2007 | JVC AV-27530 27" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Solid vertical line on JVC 42WV74
umm trying using it more, i had the same exact problem and we started using it more and more it has recently gone away.Check the wires as well (plug them out and back in)
Nov 09, 2006 | JVC PD-42WV74 42 in. Plasma EDTV
JVC AV27F476 27" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
