Question about HP Pavilion dv6000z Notebook
Hi does anybody know what make and model of 1GB ram can I use for
Hi does anybody know what make and model of 1GB (or 2GB)ram will compatible and will work on my computer.
HP D530C
AS#305374-001
HP s/n USU4390TC8
I hope this will help.Thank you
  • flex007 Dec 19, 2008
    but I do not know if the motherboard is compatible or supports both low density and hight density memory
  • 395 Answers
Buy a good named brand ram chip and you will be fine
  • Maximum Memory: 2048MB
  • Slots: 2 (2 banks of 1)
  • Standard Memory: 512 or 1024MB removable
  • Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
    *Not to exceed manufacturer supported memory.
    Posted on Dec 18, 2008
    A7v8x-mx 2GB (2x 1GB) don't recognize
    Sounds like you have run into a compatibility problem between your RAM and motherboard. These kinds of problems have been very common and that is why most motherboards have a supported memory list. Usually if the RAM does not work properly you can try reversing the slots that they are plugged into and make sure that your motherboard is set for the proper voltage and speed for the RAM. If it still does not work then you would most likely need either different RAM or a different motherboard.
    Feb 17, 2012 | ASUS A7V8X-MX Motherboard
    Hi, I want to upgrade my RAM from 256 MB 400MHz DDR1 (hynix) to 1GB DDR1. Do the both will work together or i would have to use 1GB alone? Im having ASUS K8V- VM motherboard. Will it be compatible with...
    It will be compatible but it is recommended, you use same type of modules(RAM)
    ie 256 MB + 256 MB
    1GB + 1GB
    Plus the advantage of using two instead of one(If you want 2GB, go for 1-1Gb two modules, depends on you) are, if one fails other works.
    Apr 24, 2011 | Computers & Internet
    Hp Compaq dx2200 MT RAM Problems
    Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
    Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
    Motherboard acer A1100-B1300A.... ????
    Knowing the model of the mobo will not do anything if you know it takes
    DDR2 5300.
    And you can find tons of 1GB,2GB,4GB sticks.
    If you want to know what memory MFG are compatible with you system
    go to the Acer website.
    As you can see at the website I posted below there are a lot of memory you can get.
    Here are 12 different brands of 5300 2GB sticks of memory.
    If your sure the motherboard takes 5300.
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010170147%201052408745%201052307859&name=2GB
    Feb 08, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
    ASUS P5VD2-MX SE recognizes only up to 2500MB RAM
    Actually you are doing better than you think, According to your MB specs it is only supposed to hold a max of 2GB (1GB per slot). The updated BIOS may be allowing for the additional 500MB.
    If you would like to verify, here is a link to the manual for your MB:
    P5VD2-MX SE Manual
    See page viii.
    Thanks for using Fixya.
    Wayne
    Sep 09, 2009 | ASUS P5VD2-MX SE Motherboard
    I want to upgrade my lenovo laptop ram memory from 1gb to 2gb by adding one more stick. i currently have ddr2 PC2-5300(333MHz) latency 5 5 5 15 2T RAM my friends advised me that BLUE SCREEN ERROR occurs...
    The rule of thumb with RAM is to always buy matching pairs. So instead of buying one new stick of 1gb its a better idea to buy two of the same kind and replace the one that is currently in there.
    Before you even think about doing this, head over to lenovo's website and make sure that the computer is compatible with 2gb(from the speed of the ram im assuming that it will, I don't know of many DDR2 computers that cant have 2gb.) you may also be able to get ram that is faster if it is compatible, The website will have all this info.
    Jul 12, 2009 | Computers & Internet
    Acer aspire rejecting memory at 2gb
    so u have three chips am i right 1gb+1gb+256mb
    basically its RAM compatibility issue check the ram specs is it ddr 2 with the specs that suits ur system or not
    if u put 1 gb and 1gb it gives u issues then kindly check the DDR2 PC???? check is it 2100 4200 or 5300 what is ur orig ram rating try the same rating and then check pls also check the bus speed is it 533mhz or 667 or 800mhz
    pls only use the compatible ram with ur laptop kingston are good with acer bcoz originally it comes with hynix chip and kingston chips nomally and sometimes samsung chips let me know about the detailed specs of all chips with all digits written on them
    pls rate me fixya if ur problem is solved
    Mar 04, 2009 | Acer Computers & Internet
    HP Pavilion dv6000z Notebook Logo
    106 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
