Question about AAD E-30 Main / Stereo Speaker
Stereo speaker suddenly stopped giving sound
One of my stereo speakers suddenly stopped giving sound. I swapped wires, and swapped the stereo channel with the other speaker, with no improvement. I've heard of a problem called "cold solder joint". Could it be the problem? If not, what other problem could it be? If it is the problem, how does one troubleshoot a cold solder joint? Any advice greatly appreciated. Sincerely, Bill Madon
    President:
  • 3,130 Answers
You will need to take the speaker apart and with an ohm meter or continuity tester, measure the resistance of the speaker right at the speaker to see if the speaker is open. if it is you have no choice then to replace the speaker. If the speaker measures a low resistance, measure the wires froom the speaker to the output wires or terminals. Some speaker manufacturers install small fuses inside their speakers. Good Luck
Posted on Mar 29, 2007
I only have left channel on speakers working have tested speakers ok, swapped pre amp boards still one channel, swapped output boards the same. What could it be? Barry
is there Sound stage output is stereo if stereo then one side is missing or broken link from ic to speaker, If mono output then use with one side 2 speaker parallel.
May 20, 2015 | Audio Players & Recorders
Lost sound in left channel?
I presume you are playing a stereo cd. Plug some other device, like headphones in to see if the computer is putting out stereo. Use the same plug as the speaker system is plugged into.
I presume you have swapped the speakers to test them.
If the speakers work, and the headphones work, it's the amp.
Nov 26, 2013 | Klipsch Promedia 2.1 Thx Computer Speaker...
Dv6000 no sound from internal speakers
If the stereo jack works, then there is no problem with the sound card or its drivers. Your speakers have played their last, most likely some internal wiring broken as speakers themselves rarely just quit.
Jan 12, 2012 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
0ne speaker has no sound wiring is ok and stereo is ok
Make and Model? Retrevo.com has many manuals and the troubleshooting sections have recommendations for this.
Or, you could swap the speaker with one that works to decide if it's a speaker or amp (channel) problem. Then isolate the wiring.
If it's internal to the receiver or the speaker you'll need a tech to look at it for a fix.
Jan 17, 2011 | Audio Players & Recorders
I have a studiomaster proline 1648 gold mixer, when i input stereo out from my pc into 2 channels. the out put is 2 xlr to amplifier speaker. but the sound is only one side (either left or right). i have...
Pleas check which side of the cable does give you sound. Lets say the red RCA line works with the right speaker. Now swap the wires at the back of your mixer ie. change the red plug to the white input on your mixer. If no sound comes through, your mixer might be dead on that channel.
Jul 16, 2010 | Audio Players & Recorders
Only one side of the speakers work passenger side
Hi have you tried using the settings on the stereo that controls the balance from front to back and side to side if you have changed these settings without knowing then the stereo output might be in the possition for the one side.
If after doing this you still have the same problem then i would remove the stereo and check all the wires are secure if they are then you need to remove the casing for the side speakers and check the wires for corrosion and make sure connected properly.
Usually the speakers wont just suddenly stop working if the problem was with the speaker then you would have noticed over time that the sound was distorted or would have sounded crackley from the speakers.
If this is not the case then check the speaker balance on stereo and then check wires.
Let me know how you get on or if you need further assistance ok
Aug 11, 2009 | 1994 Lincoln Town Car
No output from speakers in car.
Sounds like a couple speakerwires could be crossed/shortcurciting somewhere...;)
Oct 01, 2008 | JVC AM FM CD DET FACE CAR STEREO
Boat stereo/speakers
Wonder if the return line from both speakers was wired to a common earth, and you've lost that connection? If that happened, you'd end up with the two speakers in series instead of in parallel, and just playing the difference between left and right channels (so very much quieter). Check also the stereo doesn't have a separate fuse (possibly internal) for the power amp stage. A.
Mar 30, 2007 | iLO XM-MP3-CD Car Stereo
No sound from Front Speaker
take amp to a workbench, have a test speaker in hand, touch the speaker wires to each channel to see if all channels work. take each speaker to the amp and temporarily hook one at a time to see if any speaker is bad. if you eliminate the hardware, you know it's the wires in between.
Mar 02, 2007 | Mission 700 Main / Stereo Speaker
AAD E-30 Main / Stereo Speaker Logo
388 people viewed this question
Top AAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an AAD Audio Player and Recorder Expert? Answer questions, earn points and help others
