Question about Sharp LC-32SB24U 32 in. LCD TV
Picture is cut off on all sides. - Sharp LC-32SB24U 32 in. LCD TV
  • 679 Answers
Set your remote and your satellite remotes to 16x9, not 4x3, if that dosen't correct it, set to pan and scan, or wide fit. You need to mess around with the remotes until you find these menus. You should be able to dial it in so it fits nicely in the tv, good luck
Posted on Dec 18, 2008
My picture is cutting off in the side, what do i do
Do you have the picture size set to the correct aspect radio?
Sep 19, 2016 | Hisense Televison & Video
Tip
Making a wooden picture frame with perfect corners
Picture frames are very easy to make, but many people make the same very basic mistake that will ruin your frame. It is very important that you follow the carpenters rule of measure twice and cut once. If you don't cut the sides of the frame to be the same length, and you cut the angles of the corners slightly off then when you put it together the final corner won't line up.
The things that you are going to need is a miter saw, some clamps, a backer board and a drafting squares to make sure you have the right angle.
To set up take your backer board and cut off a piece that's around 4 inches to be used as a sliding marker gauge. After cutting it off attach a small piece of wood to keep the slider from shifting around.
With the saw unplugged and turned off clamp the backer board to the back of the saw. To cut the corners of the a frame you need to set the saw to a 45 degree angle. Make sure to check the angle using a drafting square align one side with the backer board and bring down the saw blade align them to make sure its a 45 degree angle. When you think that its right grab yourself a piece of scrap wood and make an initial cut. After cutting the test measure the angle to make sure that it is the right angle.
When you are ready to cut the frame itself take the four pieces of the frame and make an initial cut. Once all the boards have been cut once take your slider marker to the length that you want the sides of the frame to be and clamp it in. Take the first two sides and one at a time line it up with the backer board with the angle on the outside and the cut point against the slider. Turn on the saw and cut the other end. Repeat these steps to cut the other three sides.
After all the sides have been cut use a 90 degree angle to align the corners of the frame. Lay out all the sides of the frame and line them up as tight as you can. To connect them you can use a staple gun to staple the corners together. If you were aligning it and pushing the sides together when you stapled the corners you should have perfectly aligned corners.
Now all that's left is to sand it down and get the inside ready for a picture and stain it if you want.
on Feb 17, 2014 | Saws
Picture is too big, cut off at the sides. When I change the settings of the picture it changes (Bars on the side, ect.) But the picture is still cut off.
you have it zoomed in thats why. go to menu and change aspect ratio and zoom let meknow if that helps also you may have it zoomed in from your cable box.
Mar 23, 2011 | LG 50PS60 50 in. Plasma HDTV
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
52" rca rear projection
the picture is bent inward and shadow looking sides are cut off.
Aug 10, 2009 | RCA D52130 52" Rear Projection Television
Xbox picture gets cut off on the sides
try fiddling with the tv menu. most tvs have the zoom function now and also the ratio function. try testing those configurations starting from the default. make sure you have the zoom function set at 0 before fiddling with the ratio aspect.
Aug 14, 2008 | Samsung TX-R3075WH 30" TV
AKAI CFT2726 picture sides cut off.
If it is a picture tube type TV not a plasma or lcd try degausing the picture tube. I think Radio Shack carries degausers or find the plans for one on the net.
Feb 22, 2008 | Televison & Video
Graphics are cut off.
sounds like a sustained board not really sure a picture would help is it just on one side?
Mar 21, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Sharp LC-32SB24U 32 in. LCD TV Logo
215 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
