Question about Mitsubishi WS-55809 55" Rear Projection Television
Convergence WAY off...
My red tube must be toast, the convergence will not be corrected (green and blue are still perfect), the red has dropped a good couple of inches and I am assuming the tube needs replaced. Any ideas? Is this my problem?
  • 2 more comments
  • Therese Dec 18, 2008
    What does it look like when the red crt needs to be replaced then? I will definitely check into the convergence IC's... Thanks a lot for your help!
  • Therese Dec 19, 2008
    Thanks so much for your time and I appreciate saving some money although replacing a tube is still worth it to me if I end up having to. But I'll get the manual and the IC's first to try. This really is a great site and I'm glad people like yourself participate in these questions.
  • Anonymous Dec 28, 2008
    blue convergence is off and wont correct
  • Anonymous Dec 31, 2008
    convergence will not line up and pic is blury?
  • 106 Answers
You problem is the convergence IC's. This is much less expensive to fix than a red crt. Sometimes it is bad connections. Can you tap on the side of the tvand make the red correct itself?. If not, have the convergence IC's replaced and the problem will be solved.
Posted on Dec 18, 2008
  • tvguy171
    tvguy171 Dec 18, 2008
    Usually you will get no picture at all. Or it will be out of focus or to bright. The good thing is, Mitsubishi tubes are almost bullet proof. I can count on one hand the number of Mitsubishi tubes I have had to replace.
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Convergence adjustment aligns red and blue picture tubes to align with fixed green tube. Green image appears to skewed (possibly out of focus) in one direction making it impossible to get red and blue...
Ur tv convergence are dead.U know how to solders?Must replaced the 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Convergence problem again
I think you might need to do an advanced convergence. this is done threw the service menu. it is complicated and time consuming. however there is still a possibility that the green convergence circuit has failed. there is very little green correction since it is in the middle. most sets don't even have a green convergence circuit. however this one does. these pico fuses are "tiny yellow" look like a small resistor. chech for b+ on all 3 conv.ic's.
Jan 04, 2010 | Mitsubishi VS-45609 TV
Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Dec 07, 2009 | Samsung HCN5529W 55" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
What is Convergence IC's?
Tube-type projection TVs have separate picture tubes (CRT) for red, green and blue. Convergence is the process of getting the images from the three CRTs to line up properly so you see the correct colors on the screen. The convergence output integrated circuits (ICs) are the electronic devices which make this happen.
Mar 23, 2009 | RCA P52920BL 52" Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Fuzzy Blue...?
these set are bad about the blue tube messing up.. what happens is the convergence board witch generates alot of heat cooks the blue glycol.... basically growing algea in the blue tube... it is possible to remove the tube.. and remove glycol and clean the tube then replace and adjust..i have done a few here at the shop
Mar 14, 2008 | Akai PT4298HD Rear Projection Television
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
