Question about Protron PLTV-37 37 in. LCD Television
Protron 37" HDMI not producing sound
I just hooked up my new HDTV to a DVR box using the HDMI cable and I don't get any sound. My understanding was that HDMI was video and sound. Any ideas? Thanks, Peter
  • 2 more comments
  • Peter Hachmeister Apr 01, 2007
    Thanks for the input.
    I hooked up using component audio/video cables and everything works OK. It is only when I use HDMI that I have a problem.
  • Anonymous Nov 07, 2007
    same problem as above
  • Peebs Dec 09, 2007
    I'm having the same problem. TV was hooked up with HDMI. After months
    of perfect performance, was watching tv one night, and all of a sudden,
    no audio. I took the HDMI cable back to the store. I bought a new HDMI
    cable, and guess what? Perfect picture, NO AUDIO!!
    Audio works fine with A/V cables, but I want the audio and picture I had with the HDMI cable. Grrrr.
  • Anonymous Dec 16, 2008
    Mee too...
    Just got a new cable box with hdmi, hooked it up to the hdmi input in the back of the Protron, got a pic, but no audio. Checked the cable box for volume, it's fine, works fine in other modes too, also have a dvd player hooked up on component, audio works on that.
    I've also had hdmi probs with this tv with the PS3, so Im pretty sure the hdmi setup is ****. Get what u pay for I guess ;(
Not sure what model you have , but the original Protron 37", the hook up is a DVI and only a computer can be hooked up to this.
There is no HDMI on the original version of the Protron 37". A later version does have the HDMI hook up.
Posted on Nov 26, 2007
    President:
  • 3,130 Answers
Check the volume control on the DVR box. This is sometimes turned down. Good Luck
Posted on Mar 29, 2007
SOURCE:
LED TV takes 7-13 mins to display a picture when hooked up to cable DVR box, when hooked up w/ out DVR Does Not do that???
I would suggest you verify your cabling. Are you using HDMI cables? Connect a HDMI cable from the TV HDMI 1 to the Cable DVR Box, In the TV setup ,select HDMI 1 as source. If your Cable box does not have HDMI contact the provider for a updated box. With out the Make, Model of Box, Cable? Sat? Make, Model of TV. I don't know the connections?
Jan 26, 2013 | Televison & Video
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
How do you connect the cable to the tv? I have a dvr box but dont know where the connection on the tv is?
Cable from box to t.v , from antenna to box . If you have a hdmi cable plug into the back of the box, and plug into the hdmi input on the back or side of your t.v
Jan 17, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
May 19, 2009 | LG 37LG30 37 in. LCD HDTV
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Protron HDTV Cable hook up
if u want true hdtv buy a samsung 1080P LCD
Nov 11, 2007 | Intel VOICE D41JCTLSEURO PFU CT LSGS Comm...
Protron PLTV-37 37 in. LCD Television Logo
691 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
