Question about Samsung CLP 300 Laser Printer
Samsung CLP-300 Paper Feed Problem
I'm having the same paper feed problem. Tried cleaning the rubber roller but no luck! Would you be good enough to tell me how I can turn the rubber? Kids homework depends on it!
Thanks
    Problem Solver:
  • 5 Answers
I had same problem and it got resolved by lifting the front portion of the paper tray up. I put a spare USB drive under the paper tray for sufficient push upwards. It seems to be working fine now for me.
Posted on Dec 25, 2008
Printer can't pull paper
Usually the reason is the rubber rollers that feed the paper have been burnished smooth or are contaminated.
First clean the rubber roller surface with rubbing alcohol - re-try printing. If this fails, scuff the surface of the roller with 120grit sand-paper.
Good luck.
Mar 03, 2015 | HP Deskjet D1660
System keeps telling me i have a paper jam
Does the paper exit the paper tray?
If not, the half-moon shaped feed rollers may be slippery. Turn the copier on its back side to see the rollers.
Usually they are facing upwards and the rubber side is unreachable. Turn the copier back to its original position.
1. Press the copy button. When the copier starts feeding paper take the power cord off-QUICKLY. If you are quick enough the rollers remain at down position and you can clean them with some kind of rubber cleaning liquid or solvent. Perhaps alcohol, but it tends to dry out the rubber surface.
Jul 04, 2010 | Xerox WorkCentre 4150 Black and White...
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
E2 error code on Xerox work centre xd series 120f copier
e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
Nov 05, 2009 | Xerox Office Equipment & Supplies
Won't print
Hi, try a smaller quantity of paper in the paper feed tray. Also check the paper pick-up mechanisms rubber roller for too much smoothness. If the rubber roller feels too smooth, Use a lint free cloth dipped in alcohol to "clean" them.
Apr 30, 2009 | HP Officejet 7210 All-In-One InkJet...
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Misfeed on lanier 7320
I like your pictures.... Have you tried to clean the feed roller with a slittly damp rag with Simple Green or WD-40? You can try that and wipe the extra off. They both clean the rubber roller's. If that works good, that means the feed rollers are worn and need replacing. But you may also need the paper pick-up feed clutch. You said you can still run paper throw the by-pass. Good Luck
Dec 11, 2008 | Office Equipment & Supplies
Paper jams
The feedrollers are most likely worn out. Maybe not smoothe but just tacky.
You can try removing the paper tray. Then take some cleaner, alcohol or some liquid soapy cleaner, fantstic, or soemting like that, and clean the rubber rollers. Clean them 2 or 3 times with a cloth dampned with the cleaner.
since the jams are in the tray, I am sure those rollers are either dirty or smoothe.
If you need more info let me know and I will send you my E-mail address so you can order and replace them on your own if you don't have a maintenance agreement with someone.
Dec 22, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Not feeding paper copies from adf
is the add toner light on if it is it will only make one copy @ a time.
Nov 02, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Paper not picking up and alarm light comes on/stays on
Hi, You have the right idea of cleaning the rubber rollers behind the tray, (if the paper will feed through once then we can eliminate the idea of a paper jam)unfortunantly, when the rollers get too worn out then cleaning is not effective. I work on alot of Brother 5140 printers which look very similar to this model, and we pull out the tray,take the pick roller off of the printer, pull off the rubber part of the roller and rotate it 180 degrees from it former position which gives it a new area of wear. Usually that's a pretty good fix, and it isn't too hard to do, just make sure to note how it was put together before taking it apart. Good luck.
Aug 29, 2007 | Brother HL 1440 Laser Printer
Samsung CLP 300 Laser Printer Logo
367 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
