Question about Nikon COOLPIX Cameras
Broken Battery Compartment Cover
Where can I get my battery compartment cover repaired/replaced?
  • 26 Answers
I haved the battery cover ,call me 786-4361121 new original nikon
Posted on Dec 18, 2008
How do I replace batteries inMicrosoft 2000 keyboard? Casandra return
  1. Turn the device upside down, and then remove the battery compartment cover.
  2. Insert new batteries. Make sure that you align the positive and negative ends correctly, as specified by the battery compartment labels.
  3. Close the battery compartment cover.
Aug 07, 2018 | Computers & Internet
How do i remove battery in kyocera c6742, will not charge or turn on
Install or replace the battery - Kyocera Hydro EDGE
  1. Slide the lock switch to the right to unlock the battery cover.
  2. Lift the battery cover off from the Battery Compartment Release slot on the bottom of the handset.
  3. To remove the battery, lift from the slot on the bottom of the battery. To insert the battery, place the top of the battery in the compartment, ensuring the gold contacts on the battery meet with the gold contacts in the battery compartment and then press the bottom of the battery into place.
  4. Reattach the battery cover and slide the lock switch to the left to secure the battery cover.
Dec 18, 2017 | Kyocera Cell Phones
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
Hello, I have a Sportline Digital Motion Sensor.
Do you mean the screen is blank or you cannot remember how to program it? Was it working perfect until you replaced the Battery?
Make sure the battery is inserted with the positivet side up?
Manual is here: http://www.sportline.com/manuals/370.pdf
Replacing the battery: 1. Unscrew the battery compartment cover on the backside of the unit using a small Phillips screwdriver and remove the cover. 2. Remove the exhausted battery from the unit, and insert a new battery (be sure to place the positive (+) side of the battery is visible, facing toward the battery compartment cover). 3. Replace the battery compartment cover on the battery compartment and fasten the screw (CAUTION: do not over tighten).
Dec 14, 2010 | Sportline 370 Traq Motion Sensor Pedometer...
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
How do you replace the battery
Battery Installation
1) Grip the front of the mouse (the end with the buttons) with your left hand.
2) With your right hand hold the back of the mouse (end opposite the buttons) with your thumb on the bottom, and your index finger and middle finger resting on top.
3) Grip the mouse firmly, pressing down slightly on the GE logo on top of the mouse with the index and middle finger of your right hand, then pull back to release the battery cover.
4) Set the battery compartment cover aside. Insert 2 AAA batteries, being sure to match the polarity of the batteries with the polarity markings inside the battery compartment.
5) Replace the battery compartment cover.
6) Re-link your mouse. See Section 5.
Dec 10, 2009 | GE Wireless Optical Mini Mouse 3087897985
Broken battery compartment cover
The doors are about $20 on ebay. Heres a link for you:
http://cgi.ebay.com/KONICA-MINOLTA-Z6-BATTERY-DOOR-CAP-COVER-REPAIR-PART_W0QQitemZ170153738005QQihZ007QQcategoryZ64352QQrdZ1QQssPageNameZWD1VQQcmdZViewItem?_trksid=p1638.m118
Jan 03, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Camera was dropped and is not on
Take batteries out and have them checked, and make sure they are fully charged. Take a pencil eraser and clean/polish the contacts at base of the battery compartment Take a look at the battery-comp cover place and make sure the contact plate is firm replace batteries switch on OK No? Open the battery compartment, place a piece of foil across the batteries and shut it - turn on -OK No? Press the cover in OK No? Them it has broken beyond your reach and needs repair or replacement
May 22, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Cameras Logo
167 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
