Question about IBM (01K7207) SCSI Controller
Commands to scsi controllers in linux
Well i have a e series server, one scsi controller.
I need to know so many commands to monitoring the scsi work, i found ipssend, but someone tell me anothers that you can see logs, and if you change the scsi hdd show to you the sync about the new scsi controller whit all scsi controller. Any way, i want to learn about scsi and commands to work scsi on linux, you can help me with a tutorial or any digital book.
  • 3 Answers
SOURCE: I took out all my my old SCSI drives and put in 4 new ones. Now I can't do anything!
I had the same problem.
There is a cd that came with the server called "IBM RAID Support" that is a must have to reconfigure the hard drives.
It took me a week to find the ISO image.
I will upload the cd via FTP and send you the link.
Posted on Jun 17, 2009
ciscoroute
  • 87 Answers
SOURCE: ibmserver x3400 fatal error
Have you checked the IBM website for BIOS and any firmware to download and update for the controller? It can get to be a maze with server cards.
Posted on Jul 07, 2009
inovagent
  • 111 Answers
SOURCE: need x series 226 IBM server drivers
What is is OS? Do you need the drivers for the for the RAID controller? Which variant of the 226 is it? Feel free to contact me through my website on business servers, especially if you're near Rockville, MD
Posted on Oct 28, 2009
SOURCE: Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Not a solution: just a follow up. Did you work this out, as I have the same problem now. For others info: the xseries 206, has 2 sata connections which can be configured as a sata raid. It also has 3 hot pluggable scsi slots. When the sata drives are not connected it boots off the scsi to win server. As soon as the satas are plug in ( 1 or 2, raid or not) it wants to boot off the sata drive. Any help would be great.
Posted on Dec 15, 2010
EMSRSERVICEG
  • 426 Answers
SOURCE: my os is windows 2003
did you ad the firm were first
Posted on Dec 24, 2010
UPDATES for Asus Eee PC Series 2G Surf
Hi i'm Rain.
Ok i need to know is that the Red hat based Linux or Or is that more compatible to the Father OS Unix.
I Have a list of commands everything from changing a User names thru Linux to By passing the XP Adminastrator passwaord .
Xandros is just a Updated Of Red Hat if i'm correct and im sure i am .
Make sure you have full administrator rights!!
Next you will need to type . Sudo usermod -g admin user
I assume you do have Sudo Access . The command will give you rights . But still like i said i need the other information.
Nov 03, 2009 | ASUS Eee PC 2G Surf Notebook
Need x series 226 IBM server drivers
Oct 26, 2009 | IBM xSeries 226 Server
Netfinity 550
Hi
The error message you are receiving "Inquiry command failed Using IBM-PC ServerRaid Host adapter" makes me think you are attaching the tape drive to the ServerRaid Controller, which is only for Hard Disks. There should be a normal SCSI interface for attaching tape drives, etc. It's possible that the ServerRaid card is a PCI (or older) plug in card, and the normal SCSI interface will be on the main motherboard. If you look on the IBM website for the Hardware Maintenance Manual, it should hopefully make things clearer.
The reason you may not be seeing the hard drives in CMOS, is because you will need to use the IBM ServerRaid Utility to view and configure the disks.
Jun 01, 2009 | IBM Netfinity 5500 M20 4RY (86624RY)...
We have a ServeRAID-6M on a server
My husband accidently uninstalled my Lexmark 1200 Series Printer, Can You PLEASE send the drivers and software to re install it
Dec 31, 2008 | IBM ServeRAID-6M Ultra320 Scsi (02r0988)...
I need to get to the configuration utility
These menus are for SCSI/SAS controllers. If your server doesnt have a SCSI/SAS controller installed, or if it is disabled then you would not receive these prompts.
Dec 30, 2008 | Dell PowerEdge 4400 Server
Adaptec 2110S Driver for WIndows Server 2008
Windows Server 2008 is still a little new to get accurate drivers for it. Check on Adaptec.com and ask if they have a generic SCSI controller that will work for Windows Server 2008.
Nov 17, 2008 | Adaptec 2110S SCSI Controller
I canĀ“t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
Ml530
There are many configuration settings, although i personally would hunt down an SCSI hard disk, many will fit from many other models just like IDE ones
Mar 24, 2008 | Compaq ProLiant ML530 Server
I want to format scsi drives and configure raid0
You can either do this in the BIOS or (easier) just run a Linux installer (such as Ubuntu) and it will offer to do it for you when it sees Windows-formatted partitions.
Jan 06, 2008 | Dell PowerEdge 2600 Server
Domain problem
Linux and UNIX smbclient command help This option has not been seriously tested and may have some problems.
Getting into Windows Safe Mode Directory Services Restore Mode (Windows domain controllers only).
Linux and UNIX wget command help.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Microsoft Windows Server Standard 2003 for...
IBM (01K7207) SCSI Controller Logo
115 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
